January 30, 2024 at 2:02 pm
kendra
SubscriberHello,
We have users running Ansys 2023 R2. They are having issues with the individual help buttons next to each option when trying to run the meshing model in Ansys Fluent. Whenever they click on any of the context help buttons next to each option, the software will show a blank white screen, freeze up, and then eventually close.
January 31, 2024 at 12:27 pm
V.P
Ansys EmployeeHi Kendra,
Does fluent crash when you click help button?
February 14, 2024 at 5:38 pm
kendra
SubscriberHello,Â
Any ideas on how this can be resolved?Â
Thanks,
Kendra
February 20, 2024 at 1:58 pm
kendra
SubscriberHello,
Are there any solutions for fixing this so I can let our users know?
Thanks,
Kendra
January 31, 2024 at 2:07 pm
kendra
SubscriberHello,
Yes, you will see the help popup for like a second and then the whole screen goes white and freezes and then crashes.
Thanks,
Kendra
February 7, 2024 at 2:10 pm
kendra
SubscriberHello,
Thanks,
Kendra
February 20, 2024 at 2:35 pm
Forum ModeratorDoes the screen or Help window go white & then is the crash just Help, Fluent or the whole PC/terminal? Do the machines have full internet access and the ability for the users to create tokens/write cookies?Â
February 20, 2024 at 3:37 pm
kendra
SubscriberHello,
At first there is just a small white box where the help text should be which disappears quickly. Then the white box goes full screen and the software becomes unresponsive and freezes. After that times out, the software closes completely. The machines do have full internet access and the ability to create tokens/write cookie to my knowledge.
Thanks,
Kendra
February 20, 2024 at 4:21 pm
Forum ModeratorOK, thanks Kendra. To be pedantic, Help closes or Fluent?Â
February 20, 2024 at 4:23 pm
kendra
SubscriberHello,
Fluent itself will become non-resoinsive and freeze up and then close whne you click on the individual help buttons next to each option.
Thanks,
Kendra
February 20, 2024 at 4:47 pm
George Karnos
Ansys EmployeeHello Kendra,
Can you check the Windows Error log files to see if there are any errors listed when trying to access help?
Event Viewer->Windows Logs->
Application
Security
SystemAlso, can you check your Firewall and Virus Scanner to see if anything is blocking communication or scripts.
February 28, 2024 at 10:19 pm
kendra
SubscriberHello,
I will say that I try to recreate this issue under my profile on the same PC but could not. So it seems to be affecting just certain users. I checked the Windows logs as requested. The only one that had errors was under Application and it was for the Fluent software crashing.
System
Provider
   [ Name]
Application Error
   [ Guid]
{a0e9b465-b939-57d7-b27d-95d8e925ff57}
   EventID
1000
   Version
0
   Level
2
   Task
100
   Opcode
0
   Keywords
0x8000000000000000
TimeCreated
   [ SystemTime]
2024-02-28T17:12:20.4809834Z
   EventRecordID
34681
   Correlation
Execution
   [ ProcessID]
18916
   [ ThreadID]
45744
   Channel
Application
   Computer
ASE-5LWPRY3.engr.msstate.edu
Security
   [ UserID]
S-1-5-21-406616777-2001817302-1446904402-32732
EventData
  AppName
cx2320.exe
  AppVersion
0.0.0.0
  AppTimeStamp
64748f4d
  ModuleName
ucrtbase.dll
  ModuleVersion
10.0.22621.2506
  ModuleTimeStamp
097c794c
  ExceptionCode
c0000409
  FaultingOffset
000000000007f61e
  ProcessId
0x81bc
  ProcessCreationTime
0x1da6a68fc7653ca
  AppPath
C:\PROGRA~1\ANSYSI~1\v232\fluent\fluent23.2.0\cortex\win64\cx2320.exe
  ModulePath
C:\Windows\System32\ucrtbase.dll
  IntegratorReportId
074eb786-ef64-41a2-86f3-8236d4724746
  PackageFullName
  PackageRelativeAppId
 Any other suggestions would be a great help.
Thanks,
Kendra
March 7, 2024 at 1:42 pm
kendra
SubscriberHello,
Just wanted to follow up to see if there are any other suggestions/ideas as to what may be causing the issue for just certain users?
Thanks
March 15, 2024 at 3:24 pm
kendra
SubscriberHello,
Just wanted to follow up on this.
Thanks
- The topic ‘Ansys Fluent Help Buttons Issue’ is closed to new replies.
4683
1565
1386
1242
