May 21, 2019 at 9:52 pmGoutham93Subscriber
Hi all,
I am trying to do a simple simulation of shock wave propagation in a multi-layer. The timescale of the problem is in nanoseconds. When I try to solve, I get an error saying: "An error occurred when the post processor attempted to load a specific result". Please see attached image for the error. I have also attached the .wbpz file to run.
I keep getting this error no matter how simple I make the structure: say having only one layer. I am not sure what I am doing wrong, please help. Â
Viewing 0 reply threads
- The topic ‘Ansys Explicit Dynamics Post processing error’ is closed to new replies.
Ansys Innovation Space
- Problem with access to session files
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Using APDL to extract stresses on a beam element.
- How to select the interface delamination surface of a laminate?
- Geometric stiffness matrix for solid elements
- Error when opening saved Workbench project
- Timestep range set for animation export
- Computation Accleration
- SMART crack under fatigue conditions, different crack sizes can’t growth
488
486
225
201
