March 26, 2022 at 12:37 pmIngo SchwarzSubscriber
I have ANSYS Discovery Structural Physics Add-on (Named User) and ANSYS Discovery Fluids Physics Add-on (Named User) in addition to ANSYS Discovery Simulation (Named User).
I cannot get the Add-on's working on my second machine, although the basic installations is working there. What do I have to do?
March 28, 2022 at 4:20 amCharudatta BandgarForum Moderator
Hello Ingo Schwarz
Let me check this, I will get back to you.
Regards.
March 28, 2022 at 5:16 amCharudatta BandgarForum Moderator
Hello Ingo Schwarz
If I understand it correctly, when you launch Discovery in refine mode, you are not able to do that. Can you please share a screenshot of the error message you are getting?
Regards.
April 13, 2022 at 10:14 amIngo SchwarzSubscriber
Charudatta Bandgar I am surprised that there is no comment available yet. Could you please let me know, what the status is. Thanks.
March 29, 2022 at 4:34 pmIngo SchwarzSubscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Hi!
I am not sure, if I understand correctly or if I did not make the subject clear. In my Ansys Administration Account I have the add-ons. There are two installations permitted and only one is used. When I start Discovery on a non addressed PC, it will open up and it does not ask for add-on permit. It simply does not take the license, although it is available. Therefore I can put my settings into a run, but it won't proceed, as it says the computer is not capable to run "Analyze Phase" due to a missing adequate graphics card and one line later it says, you need the add-on. So how can I get the add-on active? I attach a screen-shot for your informationThanks
Ingo
- The topic ‘Ansys Discovery 2022R1 – Structural and Fluid Add-on’ is closed to new replies.
- Unable to attach geometry 2024 R2
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Inventor 2025 files
- SpaceClaim stops sharing topology
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- solidwork parameters for optimization in ansys
1727
624
599
591
366
