July 11, 2024 at 4:32 pm
July 12, 2024 at 4:07 pm
Mike Pettit
Ansys EmployeeHello,
This looks like a defect in the Aqwa Workbench editor. Which version of the Ansys software are you using?
Are you able to get results for any other joints?
Mike
July 16, 2024 at 5:21 pm
July 19, 2024 at 12:43 pm
Mike Pettit
The problem of 'SC _PLS -Key Number 4 Not Found' for the joint reaction results will not be related to the data that you have defined, it is more likely to be a defect in the program. I will try to reproduce the issue on my own computer. There is no default data for stiffness/damping/friction coefficients in a joint, i.e. the moment around a ball-and-socket joint is zero if these coefficients are left as zero. Please see also my reply to your other post: change position hinged connector (ansys.com)
Mike
- The topic ‘ansys aqwa :EiSC _PLS -Key Number 4 Not Found.How to solve?’ is closed to new replies.
