July 14, 2021 at 8:12 pm
komal.gada
SubscriberJuly 21, 2021 at 1:51 pmGeorge Karnos
Ansys Employeecan you please check the RSM Job log file and paste it's whole contents here?
Open RSM Job Monitoring and Highlight Job
Right - click in bottom window and choose select all the right-click and choose copy.
paste copied txt in this post.
July 23, 2021 at 5:47 pmkomal.gada
SubscriberRSM Version: 20.1.420.0, Build Date: 11/18/2019 9:21:16 AM
RSM File Version: 20.1.0-beta.54+Branch.release-20.1.Sha.cad62d08b9fab3e9bb01d96706997e9f2c7ec7d2
RSM Library Version: 20.1.0.0
Job Name: Default Test Job
Type: SERVERTEST
Client Directory: C:\Users\012542567\AppData\Local\Temp\RsmConfigTest\0ec3nqee.iqj
Client Machine: COE-Ceers-1
Queue: Default [ITS, default]
Template: SERVERTEST
Cluster Configuration: ITS [hpc.its.csulb.edu]
Cluster Type: TORQUE
Custom Keyword: blank
Transfer Option: External
External Storage Type: SSH-SCP
Staging Directory: /research/COE/CEERS/Komal/rsmstaging
Delete Staging Directory: True
Local Scratch Directory: blank
Platform: Linux
Using External Communication Protocol
Remote Account: 012542567
Using SSH for inter-node communication on cluster
Cluster Submit Options: blank
Normal Inputs: [*,commands.xml,*.in]
Cancel Inputs: [-]
Excluded Inputs: [-]
Normal Outputs: [*]
Failure Outputs: [-]
Cancel Outputs: [-]
Excluded Outputs: [-]
Inquire Files:
normal: [*]
inquire: [*.out]
Submission in progress...
Runtime Settings:
Job Owner: CAMPUS-DOMAIN\012542567
Submit Time: Friday, July 23, 2021 10:43 AM
Alternate Platform Directory: /research/COE/CEERS/Komal/rsmstaging/j4bp3bkk.a1c
Transferring file: commands.xml| 2 kB |2.6 kB/s | ETA: 00:00:00 | 100%
Transferring file: tEst WiTh sPaCe.in| 0 kB |0.0 kB/s | ETA: 00:00:00 | 100%
Transferring file: tEsT.in| 0 kB |0.0 kB/s | ETA: 00:00:00 | 100%
2.76 KB, 3.91 sec (.71 KB/sec)
JobType is: SERVERTEST
Final command platform: Linux
RSM_PYTHON_HOME=C:\Program Files\ANSYS Inc\v201\commonfiles\CPython\3_7\winx64\Release\python
RSM_HPC_JOBNAME=RSMTest
Distributed mode requested: True
RSM_HPC_DISTRIBUTED=TRUE
Running 5 commands
Job working directory: C:\Users\012542567\AppData\Local\Temp\RsmConfigTest\0ec3nqee.iqj
Number of CPU requested: 1
AWP_ROOT201=C:\Program Files\ANSYS Inc\v201
Testing writability of working directory...
If you can read this, file was written successfully to working directory
Writability test complete
Checking queue default exists ...
Transferring file: control_eb313f11-84b1-475 | 3 kB |3.7 kB/s | ETA: 00:00:00 | 100%
Transferring file: clusterjob_eb313f11-84b1- | 1 kB |1.7 kB/s | ETA: 00:00:00 | 100%
5.47 KB, 1.96 sec (2.79 KB/sec)
JobId was parsed as: 1975441.clusterhn.cluster.com
Job submission was successful.
Trying to download diagnostic output files.
Transferring file: exitcode_eb313f11-84b1-47 | 0 kB |0.0 kB/s | ETA: 00:00:00 | 100%
AWP_ROOT201 is not set on cluster compute node.
ClusterJobs Command Exit Code: 1000
No files transferred.
Trying to cleanup diagnostic files.
No files to transfer.
July 28, 2021 at 6:06 amkomal.gada
SubscriberHello Does the user need any level of permission to /ansys_inc/v201/ folder?
My IT administrator has added "$AWP_ROOT201 /ansys_inc/v201" to path globally on all nodes.
But I still get the following error:
Upon adding the following line in users .bashrc "env $AWP_ROOT201 /ansys_inc/v201/"
I get an error saying permission denied to /ansys_inc/v201
Thanks Komal
Viewing 3 reply threads- The topic ‘ANSYS 2020R1 RSM Windows to Linux setup issue.’ is closed to new replies.
5664
1890
1419
1304
