June 16, 2020 at 2:15 pmkabokaSubscriber
I have case and dat files of a simulation and would like to load into CFD-Post, however when I try to load results it gives a no solution history was found error as in the picture. It just loads the ones that have case files, other time steps have just dat files due to memory concerns.Â
It loads all files in Fluent 14.2 version, however here it says the type of the time steps as "partial":Â
Does anyone know how to load other data in CFD-Post 19.2 ? Thanks in advance.
Have a nice day
Bora
June 17, 2020 at 1:51 pmRobForum Moderator
Not sure, have you moved any files or renamed anything?Â
June 17, 2020 at 2:31 pmkabokaSubscriber
Nope I have just used another cluster for my simulation and copied the files from it. Same files work on CFD-Post 14.2.
- The topic ‘Ansys 19.2 CFD-Post error: no solution history was found’ is closed to new replies.
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- convergence issue for transonic flow
602
599
591
366
