February 23, 2023 at 11:09 amEmily ManchesterSubscriber
I have recently installed Ansys 17.0 and the License Manager will not even start/open. I can successfully open/load ICEM CFD, and then it soon fails because it cannot connect to a license. I am unsure why this is happening - there did not seem to be any issues with installation. I have also installed the exact same version (using the same installation file) on another PC previously without issue. I am not sure if it is relevant but I am using a university run Windows 10 laptop.
Has anyone else had this problem before? Does anyone know why the License Manager will not start?
Thank you
February 27, 2023 at 4:24 pmANSYS_MMadoreAnsys Employee
Ansys 17.0 is no longer a supported release. Do you have an Ansys issued license specifically for this one laptop machine? Or are you trying to just run ICEM 17.0 and connect to an existing University license server?
- The topic ‘Ansys 17.0 License Manager Fails to Open’ is closed to new replies.
- Workbench license error
- Unexpected error on Workbench: Root element not found.
- not able to get result
- Unable to recover corrupted project in Workbench
- Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
- Questions and recommendations: Septum Horn Antenna
- AQWA: Hydrodynamic response error
- Tutorial or Help for 2 way FSI
- Moment Reaction probe with Large deformation
- 2 way coupled FSI for ball bearing
1241
543
523
225
209
