June 4, 2021 at 1:20 pm
vinaychandrakar11
SubscriberHello Everyone,
I want to simulate the flow of gaseous species over the coating of catalyst. I considered a catalyst coating as a porous medium.
I am planning to solve mentioned PDE in fluent for porous domain. Equation and geometry are attached.
June 5, 2021 at 9:10 amDrAmine
Ansys EmployeeA) does depend if you want to account for direction dependent diffusion.
B) the terms in your equation are all built-in. If something is missing it can be added. If you want to know the background please refer to the mentioned references in the manual
C)manual is just a how to. Theory is found elsewhere.
June 5, 2021 at 11:10 amvinaychandrakar11
SubscriberThanks for replying DrAmine A) Mine is isotropic diffusion so I dont think it will affect much, but if I will tick on anisotropic diffusion box then matrix appears and if its diagonal elements are 1 and other elements are zero then it would be isotropic only, right?
B) If I will not check on the anisotropic diffusion then I will not be able to choose Brinkmann option (which I want to find out the changes with and without use of anisotropic diffusion).
C) I didnt find anything about Brinkmann term in both user guide as well as theory guide. Do I have to read it somewhere elese?
June 7, 2021 at 11:12 amDrAmine
Ansys EmployeeA. Yes
B. No. it has noting to do with species diffusion that Brinkman viscosity.
C. 3 Keywords are enough to have some information: Brinkmann viscosity porous.
June 9, 2021 at 6:59 amvinaychandrakar11
Thank You so much DrAmine for clearing my doubts.
Viewing 4 reply threads- The topic ‘Anisotropic Species Diffusion term meaning in cell zone condition of Porous media’ is closed to new replies.
5774
