February 2, 2021 at 9:57 pmAwladSubscriberDear Support Engineers:nI am doing a steady state thermal simulation. At the end, I am getting temperature plot (using PLNSOL, TEMP command). Is it possible to see the animation? I mean how the temperature is changing within 1 second time? I tried to find this option under Plot Control, but I was not successful. nAny comments or suggestions will be highly appreciated. Thanks,nAwlad.n
February 3, 2021 at 10:40 am1shanAnsys EmployeeHello ArraynA steady state analysis would be a wrong choice for your problem, since it does not tell you how the temperature varies with time rather gives you the final temperature distribution after an infinite time. You should use the transient thermal solver instead.nCheck out these tutorials /courses/index.php/courses/heat-transfer/lessons/homework-quizzes-simulation-examples-overview-of-heat-transfer/nRegards,nIshan.n
February 11, 2021 at 2:20 amAwladSubscriberMany, many thanks.nAwald.n
- The topic ‘Animation of Steadt State Thermal Simulation’ is closed to new replies.
Ansys Innovation Space
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Image to file in Mechanical is bugged and does not show text
- Timestep range set for animation export
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
599
591
555
366
