December 5, 2019 at 5:43 pm
Jerin
SubscriberHi,  I was running a simulation on ANSYS MECHANICAL PREMIUM and in the middle of the run i got an error "An unknown error occurred during solution. Check the solver output." I checked the solver output and found there was neither any warning nor an error msg as shown in the attached image below. My solution didnt hand any bisection/divergence issue it was converging nicely as you can see in the attached image. I also got an error message something like "ANSYS SERVER LICENSE LOST" and for few minutes I was not able to access Mechanical.
December 5, 2019 at 6:53 pm
Divya Shree Surendran
Ansys EmployeeHello Jerin,
Are you using the ANSYS Student package?
If not, are you pointing to a remote license server from your machine? In that case it could be a network interruption issue. Do you see this error often?
December 6, 2019 at 1:11 am
tsiriaks
Ansys EmployeeIn Workbench, click Tools -> License Preferences , then post screenshots of all 4 tabs in that window.
December 7, 2019 at 12:00 am
Jerin
SubscriberHi dsunder,
I am not using the student version of the license. Yes I am running it remotely and now a days I am seeing it more often and unfortunately after this error i lose all of my run data. And sometime if I try to re run the same model it doesn't work until try to run it twice or thrice.Â
December 7, 2019 at 12:05 am
December 9, 2019 at 5:41 pm
Thank you for the details. Please edit the ansyslmd.ini file under C:Program FilesANSYS IncShared FilesLicensing
ANSYSLI_TIMEOUT_TCP=120
ANSYSLI_TIMEOUT_CONNECT=60
ANSYSLI_FNP_IP_ENV=1
ANSYSLI_TIMEOUT_FLEXLM=15
ANSYSLI_FLEXLM_TIMEOUT_ENV=10000000
Save the file and then try the solve again.
December 11, 2019 at 12:05 am
- The topic ‘An unknown error occurred during solution.’ is closed to new replies.
5669
1890
1419
1304
