Ansys Innovation Courses
Provide feedback or ask questions related to the Ansys Innovation Courses content.
An internal solution magnitude limit was exceeded
    • 1802039
      I am trying to learn heat transfer simulation from innovation course. I have downloaded the materials from this course-"https://innovationspace.ansys.com/courses/courses/heat-transfer/lessons/homework-quizzes-simulation-examples-overview-of-heat-transfer/". After downloading and rerunning the given save file I get this error- "An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports.  Please see the Troubleshooting section of the Help System for more information. An internal solution magnitude limit was exceeded. (Node Number 2021, Body Solid, DOF TEMP) Please check your Environment for inappropriate load values or insufficient supports.  You may select the offending object and/or geometry via RMB on this warning in the Messages window.  Please see the Troubleshooting section of the Help System for more information."
      Here is the content data-"https://ansys13.ansys.com/AnsysInnovationCourses/MBU/HeatTransfer/HeatTransferOverview/SE02ThermalAnalysisOfHeatPot.zip".
      I am trying best but can't find any possible solution. I even didn't change any data in the save file, just cleared the generated data and re-run it. I am using Ansys 2024 R2.
      Can anyone help to troubleshoot?
      Thank you.
    • Ashish Khemka
      I assume this issue was resolved. Please let me know if you have any queries.
      Ashish Khemka
