Ansys Products
Ansys Products
After restarting, the shell elements on the exterior surface of the vehicle were
    • 373352238
      In the first step, I applied an axial load to my column. Then, in the second step, I imported a vehicle model. However, at the beginning of the simulation, the shell elements on the exterior surface of the vehicle were deleted, starting with the points and then the shell elements.I checked the vehicle model but couldn't find the issue. Could anyone help me understand where the problem might be? Thank you in advance for your responses!
    • mjmiddle
      Does that mean you used External Model system to import? What application is this? LS-Dyna pre? Ansys Mechanical? Whag format is the file you imported? Were there errors or warnings? There will normall be messages when something in the impirt is skipped. Check the message panel in Mechanical and workbench.
      • 373352238
        I used LS-PrePost for modeling and successfully imported the vehicle model into the component model without any errors during the import process.
