Ansys Products
Ansys Products
Adjustment between two boundary layers in ansys meshing watertight geometry
    • 100041488
      Hi all,
      I am creating an unstructured mesh using the watertight scheme in ANSYS Meshing, but I am having trouble adjusting the two adjacent boundary layers. Specifically, I would like to control the step transition between them. You can refer to the attached file for clarification. Currently, I only have four cells to work with, but I would like to have, for example, 10 or more. Does anyone know how to achieve this? (The geometry is that of a cylinder with external flow, and I am trying to adjust the boundary layers around the cylinder.)
      Many thanks in advance and best regards.
    • 100041488
      Hi again,
      I posted this question, but I haven't received a response yet. My issue is quite urgent, and I would greatly appreciate any assistance!!. Thank you in advance for your help. ?
      Best regards
  • The topic ‘Adjustment between two boundary layers in ansys meshing watertight geometry’ is closed to new replies.
