Electronics
Electronics
Adding ports to a layout component file
    • juan_antonio_vega
      I am having troubles to add ports to a Layout Component File in HFSS.
      The procedure I am using is:
      1. in HFSS 3D Layout, I select my board file, then Export as Layout Component.
      2. In HFSS Design, I created the Layout Component, using Create Layout Component and selected my exported file of step 1.
      3. Once in HFSS I tried to add ports, but Cannot select any of the features pads, traces etc.
      is this an incorrect procedure? what should be the best I should use? Should I add the ports from HFSS 3D layout side.
      if so what will be the appropiate port type for components like resistors, capacitors, inductors. In my simulation I want to have flexibility to change those kind of component values in schematic and not needing to run HFSS solution every time I change a value.
      Thanks!
      Juan
      Then
    • juan_antonio_vega
      I already found my mistake and no need an answer here, Thanks
  • The topic ‘Adding ports to a layout component file’ is closed to new replies.
