TAGGED: acoustics, ansys-workbench, mechanical, structural, workbench
June 25, 2021 at 4:37 am
PrabhuManickam
SubscriberHi,
I seen many videos they doing acoustic harmonic analysis.
1st they do Modal Analysis
2nd Harmonic response analysis
3rd Harmonic Acoustics
Modal analysis results is given to Harmonic response. Then harmonic response result is given as an input to harmonic acoustic.
(Harmonic Response results gives Imported velocity to harmonic acoustic)
Now how they find the dB levels using the velocity values? What is the equation behind it to calculate it?
General Formula for dB = log (pressure difference)
In ansys how they calculate the dB using the Velocity one? Please say the physics and calculation behind of that analysis.
June 25, 2021 at 7:00 amErKo
Ansys EmployeeHi
So when you transfer the velocities to the harmonic acoustic system, we will then solve there for the acoustic pressures (generated by this velocity excitation).
Thus pressure is the main variable we solve for in an acoustic analysis ( just as displacements are in a structural analysis).
(See the acoustic theory in our help for more info on the equation solved)
Finally with the pressures (P_ansys) calculated in the the acoustic domain, we can calculate the sound pressure levels in dB using the equation: 20*Log10(P_ansys/sqrt(2)/P_ref), where P_ref (reference pressure) is equal to 20 microPa. See chapter 8.6 in the ansys theory reference for details.
All the best
Erik
May 10, 2023 at 4:44 pmuday kiran
Subscriberfor sound reduction using acoustic matrial which method we have to use in ansys sir .
May 11, 2023 at 7:00 amErKo
Ansys EmployeeÂ
This post is very old and not directly related to your question. I would suggest to open a new one explaining what you want to do in more detail.
Erik
Viewing 3 reply threads- The topic ‘Acoustic – Physics behind the Analysis’ is closed to new replies.
6570
1311
