August 24, 2022 at 1:02 pm
itdesk
SubscriberDear Support,
I have installed version 12.5ÂI have installed the latest versions of both the client and ansys license server. I have also ensured the license is up to date. I do have a green check mark from the client side. I do run all installs as Admin.ÂThank you,ÂRobert416 319 8383milver73@yorku.caÂÂ
August 24, 2022 at 7:13 pm
ANSYS_MMadore
Forum ModeratorI've reached out directly on this issue.
August 25, 2022 at 6:08 pm
ANSYS_MMadore
Forum ModeratorFor reference, starting with 2021R1 the applications must communicate through ansyslmd and lmgrd, where past releases used lmgrd and the ansysli_server process on 2325.
In this case all your other products worked because they were running versions 2020R2, using just the lmgrd and ansysli_server ports which were already open on the firewall. So adding the ansyslmd process to the Windows firewall resolved the issue.
Thanks
Matt
April 7, 2023 at 3:29 pm
James Topper
SubscriberI am having a similar issue and dont know how to resolve it. When I test the license I get the green check mark, but as soon as I launch STK I get an error message: "A current STK license could not be found..."
Any assistance would be appreciated. Thanks.Â
April 7, 2023 at 4:32 pm
ANSYS_MMadore
Forum ModeratorJames, what version are you running? Do you have other Ansys products installed? Do they work? If you select the "FlexNet Publisher License Status" or "Features in Use" button in the Licensing Settings utility, what is reported?
July 19, 2023 at 2:19 pm
curtis.fox
SubscriberI am having the same issue with the STK license. STK 12.7 was installed along with ANSYS 2023R1 (which does work). Ansyslmd was added into the firewall for access but the error still occurred.
What is the next step?Â
Curt
July 19, 2023 at 2:24 pm
ANSYS_MMadore
Forum ModeratorIf you select the "FlexNet Publisher License Status" or "Features in Use" button in the Licensing Settings utility, what is reported?
July 19, 2023 at 2:42 pm
July 19, 2023 at 2:49 pm
July 19, 2023 at 3:02 pm
July 19, 2023 at 3:08 pm
ANSYS_MMadore
Forum ModeratorPlease share the full output of running "Features in use".
July 19, 2023 at 3:10 pm
curtis.fox
SubscriberHere you go.....
1055@police.ceas1.uc.edu ------------------------------------------ lmutil - Copyright (c) 1989-2022 Flexera. All Rights Reserved. Flexible License Manager status on Wed 7/19/2023 11:10 [Detecting lmgrd processes...] License server status: 1055@police License file(s) on police: C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files\ansoftd.lic:C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files\ansyslmd.lic:C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files\license-ansys.lic: police: license server UP (MASTER) v11.17.2 Vendor daemon status (on police): ansyslmd: UP v11.17.2 Feature usage info: Users of granta_edupack: (Total of 60 licenses issued; Total of 0 licenses in use) Users of 1spacdes: (Total of 550 licenses issued; Total of 0 licenses in use) Users of a_jt_reader: (Total of 550 licenses issued; Total of 0 licenses in use) Users of a_spaceclaim_catv5: (Total of 550 licenses issued; Total of 0 licenses in use) Users of a_spaceclaim_dirmod: (Total of 550 licenses issued; Total of 0 licenses in use) Users of a_spaceclaim_faceteddata: (Total of 550 licenses issued; Total of 0 licenses in use) Users of acdi_adprepost: (Total of 550 licenses issued; Total of 0 licenses in use) Users of acfd_vki: (Total of 550 licenses issued; Total of 0 licenses in use) Users of acfx_bldmdlr: (Total of 550 licenses issued; Total of 1 license in use) "acfx_bldmdlr" v9999.9999, vendor: ansyslmd, expiry: 01-jul-2024 vendor_string: customer:00419073 tp:a floating license Roshan Baskaran Cuppoletti12 Cuppoletti12 23728 (v2021.0512) (police/1055 1201), start Tue 7/18 10:08 Users of acfx_pre: (Total of 550 licenses issued; Total of 0 licenses in use) Users of acpreppost: (Total of 550 licenses issued; Total of 0 licenses in use) Users of advanced_meshing: (Total of 550 licenses issued; Total of 0 licenses in use) Users of afsp_gui: (Total of 550 licenses issued; Total of 0 licenses in use) Users of afsp_optigrid: (Total of 550 licenses issued; Total of 0 licenses in use) Users of afsp_viewmerical: (Total of 550 licenses issued; Total of 0 licenses in use) Users of agppi: (Total of 550 licenses issued; Total of 1 license in use) "agppi" v9999.9999, vendor: ansyslmd, expiry: 01-jul-2024 vendor_string: customer:00419073 tp:a floating license Roshan Baskaran Cuppoletti12 Cuppoletti12 23728 (v2021.0512) (police/1055 701), start Tue 7/18 10:08 Users of am_module: (Total of 550 licenses issued; Total of 0 licenses in use) Users of am_prep: (Total of 550 licenses issued; Total of 0 licenses in use) Users of am_print: (Total of 550 licenses issued; Total of 0 licenses in use) Users of ans_act: (Total of 550 licenses issued; Total of 0 licenses in use) Users of anshpc: (Total of 900 licenses issued; Total of 134 licenses in use) "anshpc" v9999.9999, vendor: ansyslmd, expiry: 01-jul-2024 vendor_string: customer:00419073 tp:a floating license Ryan Cuppoletti3a.CEAS1.uc.edu Cuppoletti3a.CEAS1.uc.edu 25796 (v2022.0502) (police/1055 2801), start Tue 7/18 10:24, 60 licenses Ryan Cuppoletti3a.CEAS1.uc.edu Cuppoletti3a.CEAS1.uc.edu 5652 (v2022.0502) (police/1055 3601), start Tue 7/18 10:45, 56 licenses chakraun MME-KNBR-F23D.CEAS1.uc.edu MME-KNBR-F23D.CEAS1.uc.edu 14940 (v2022.0502) (police/1055 5401), start Tue 7/18 12:51, 6 licenses vonoja Cuppoletti14 Cuppoletti14 13148 (v2021.0512) (police/1055 1105), start Tue 7/18 14:48, 12 licenses Users of ansrom: (Total of 550 licenses issued; Total of 0 licenses in use) Users of ansys: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aqwa_pre: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aqwa_solve: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_creo_fie: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_creo_level1: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_creo_level2: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_creo_level3: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_creo_odo: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_creo_ost: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_fie: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_hud: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_level1: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_level2: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_level3: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_opd: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_ost: (Total of 550 licenses issued; Total of 0 licenses in use) Users of aspeos_solver: (Total of 550 licenses issued; Total of 0 licenses in use) Users of avrxp_snd_level1: (Total of 550 licenses issued; Total of 0 licenses in use) Users of cfd_base: (Total of 550 licenses issued; Total of 7 licenses in use) "cfd_base" v9999.9999, vendor: ansyslmd, expiry: 01-jul-2024 vendor_string: customer:00419073 tp:a floating license Roshan Baskaran Cuppoletti12 Cuppoletti12 21060 (v2021.0512) (police/1055 401), start Tue 7/18 10:07 Roshan Baskaran Cuppoletti12 Cuppoletti12 14352 (v2021.0512) (police/1055 1801), start Tue 7/18 10:08 Ryan Cuppoletti3a.CEAS1.uc.edu Cuppoletti3a.CEAS1.uc.edu 25796 (v2022.0502) (police/1055 2601), start Tue 7/18 10:24 Ryan Cuppoletti3a.CEAS1.uc.edu Cuppoletti3a.CEAS1.uc.edu 5652 (v2022.0502) (police/1055 3401), start Tue 7/18 10:45 chakraun MME-KNBR-F23D.CEAS1.uc.edu MME-KNBR-F23D.CEAS1.uc.edu 14940 (v2022.0502) (police/1055 4902), start Tue 7/18 12:51 vonoja Cuppoletti14 Cuppoletti14 13148 (v2021.0512) (police/1055 3902), start Tue 7/18 14:48 mahajaty MME-MJC21D.CEAS1.uc.edu MME-MJC21D.CEAS1.uc.edu 12564 (v2022.0502) (police/1055 3207), start Wed 7/19 1:48 Users of cfd_polyflow_ui: (Total of 550 licenses issued; Total of 0 licenses in use) Users of cfd_preppost: (Total of 550 licenses issued; Total of 2 licenses in use) "cfd_preppost" v9999.9999, vendor: ansyslmd, expiry: 01-jul-2024 vendor_string: customer:00419073 tp:a floating license Roshan Baskaran Cuppoletti12 Cuppoletti12 21060 (v2021.0512) (police/1055 301), start Tue 7/18 10:07 Roshan Baskaran Cuppoletti12 Cuppoletti12 14352 (v2021.0512) (police/1055 1301), start Tue 7/18 10:08 Users of cfd_preppost_pro: (Total of 550 licenses issued; Total of 0 licenses in use) Users of cfd_solve_level1: (Total of 550 licenses issued; Total of 7 licenses in use) "cfd_solve_level1" v9999.9999, vendor: ansyslmd, expiry: 01-jul-2024 vendor_string: customer:00419073 tp:a floating license Roshan Baskaran Cuppoletti12 Cuppoletti12 25436 (v2021.0512) (police/1055 601), start Tue 7/18 10:07 Ryan Cuppoletti3a.CEAS1.uc.edu Cuppoletti3a.CEAS1.uc.edu 25796 (v2022.0502) (police/1055 2701), start Tue 7/18 10:24 Ryan Cuppoletti3a.CEAS1.uc.edu Cuppoletti3a.CEAS1.uc.edu 5652 (v2022.0502) (police/1055 3501), start Tue 7/18 10:45 Roshan Baskaran Cuppoletti12 Cuppoletti12 31620 (v2021.0512) (police/1055 4801), start Tue 7/18 11:46 chakraun MME-KNBR-F23D.CEAS1.uc.edu MME-KNBR-F23D.CEAS1.uc.edu 14940 (v2022.0502) (police/1055 5102), start Tue 7/18 12:51 vonoja Cuppoletti14 Cuppoletti14 13148 (v2021.0512) (police/1055 3802), start Tue 7/18 14:48 mahajaty MME-MJC21D.CEAS1.uc.edu MME-MJC21D.CEAS1.uc.edu 12564 (v2022.0502) (police/1055 1006), start Wed 7/19 1:49 Users of cfd_solve_level2: (Total of 550 licenses issued; Total of 7 licenses in use) "cfd_solve_level2" v9999.9999, vendor: ansyslmd, expiry: 01-jul-2024 vendor_string: customer:00419073 tp:a floating license Roshan Baskaran Cuppoletti12 Cuppoletti12 25436 (v2021.0512) (police/1055 501), start Tue 7/18 10:07 Ryan Cuppoletti3a.CEAS1.uc.edu Cuppoletti3a.CEAS1.uc.edu 25796 (v2022.0502) (police/1055 2501), start Tue 7/18 10:24 Ryan Cuppoletti3a.CEAS1.uc.edu Cuppoletti3a.CEAS1.uc.edu 5652 (v2022.0502) (police/1055 3301), start Tue 7/18 10:45 Roshan Baskaran Cuppoletti12 Cuppoletti12 31620 (v2021.0512) (police/1055 4701), start Tue 7/18 11:46 chakraun MME-KNBR-F23D.CEAS1.uc.edu MME-KNBR-F23D.CEAS1.uc.edu 14940 (v2022.0502) (police/1055 5002), start Tue 7/18 12:51 vonoja Cuppoletti14 Cuppoletti14 13148 (v2021.0512) (police/1055 3702), start Tue 7/18 14:48 mahajaty MME-MJC21D.CEAS1.uc.edu MME-MJC21D.CEAS1.uc.edu 12564 (v2022.0502) (police/1055 907), start Wed 7/19 1:48 Users of cfd_solve_level3: (Total of 550 licenses issued; Total of 0 licenses in use) Users of disco_level1: (Total of 550 licenses issued; Total of 0 licenses in use) Users of disco_level2: (Total of 550 licenses issued; Total of 0 licenses in use) Users of dsdxm: (Total of 550 licenses issued; Total of 0 licenses in use) Users of dyna: (Total of 550 licenses issued; Total of 2 licenses in use) "dyna" v9999.9999, vendor: ansyslmd, expiry: 01-jul-2024 vendor_string: customer:00419073 tp:a floating license student VEMAGAKS-02.CEAS1.uc.edu VEMAGAKS-02.CEAS1.uc.edu 40964 (v2021.0512) (police/1055 1901), start Tue 7/18 10:08 student VEMAGAKS-02.CEAS1.uc.edu VEMAGAKS-02.CEAS1.uc.edu 88332 (v2021.0512) (police/1055 103), start Tue 7/18 22:51 Users of dynardo_osl: (Total of 550 licenses issued; Total of 0 licenses in use) Users of dynardo_osp: (Total of 550 licenses issued; Total of 0 licenses in use) Users of dysmp: (Total of 2550 licenses issued; Total of 30 licenses in use) "dysmp" v9999.9999, vendor: ansyslmd, expiry: 01-jul-2024 vendor_string: customer:00419073 tp:a floating license student VEMAGAKS-02.CEAS1.uc.edu VEMAGAKS-02.CEAS1.uc.edu 40964 (v2021.0512) (police/1055 2001), start Tue 7/18 10:08, 15 licenses student VEMAGAKS-02.CEAS1.uc.edu VEMAGAKS-02.CEAS1.uc.edu 88332 (v2021.0512) (police/1055 203), start Tue 7/18 22:52, 15 licenses Users of elec_filter: (Total of 550 licenses issued; Total of 0 licenses in use) Users of elec_solve_2d: (Total of 550 licenses issued; Total of 0 licenses in use) Users of elec_solve_hfss: (Total of 550 licenses issued; Total of 0 licenses in use) Users of elec_solve_icepak: (Total of 550 licenses issued; Total of 0 licenses in use) Users of elec_solve_level1: (Total of 550 licenses issued; Total of 0 licenses in use) Users of elec_solve_level2: (Total of 550 licenses issued; Total of 0 licenses in use) Users of elec_solve_level3: (Total of 550 licenses issued; Total of 0 licenses in use) Users of elec_solve_maxwell: (Total of 550 licenses issued; Total of 0 licenses in use) Users of elec_solve_q3d: (Total of 550 licenses issued; Total of 0 licenses in use) Users of elec_solve_siwave: (Total of 550 licenses issued; Total of 0 licenses in use) Users of electronics_desktop: (Total of 550 licenses issued; Total of 0 licenses in use) Users of electronics2d_gui: (Total of 550 licenses issued; Total of 0 licenses in use) Users of electronics3d_gui: (Total of 550 licenses issued; Total of 0 licenses in use) Users of electronicsckt_gui: (Total of 550 licenses issued; Total of 0 licenses in use) Users of ema_charge_gui: (Total of 550 licenses issued; Total of 0 licenses in use) Users of ema_charge_solve: (Total of 550 licenses issued; Total of 0 licenses in use) Users of ema_gui: (Total of 550 licenses issued; Total of 0 licenses in use) Users of ema_solve: (Total of 550 licenses issued; Total of 0 licenses in use) Users of emag: (Total of 550 licenses issued; Total of 0 licenses in use) Users of ensight_enterprise: (Total of 550 licenses issued; Total of 0 licenses in use) Users of envision_pro: (Total of 550 licenses issued; Total of 0 licenses in use) Users of explicit_basic: (Total of 550 licenses issued; Total of 0 licenses in use) Users of fluent_meshing: (Total of 550 licenses issued; Total of 0 licenses in use) Users of fluent_meshing_pro: (Total of 550 licenses issued; Total of 0 licenses in use) Users of fluent_setup_post: (Total of 550 licenses issued; Total of 0 licenses in use) Users of fluent_setup_post_pro: (Total of 550 licenses issued; Total of 0 licenses in use) Users of forming_level1: (Total of 550 licenses issued; Total of 0 licenses in use) Users of forming_level2: (Total of 550 licenses issued; Total of 0 licenses in use) Users of forte_3: (Total of 550 licenses issued; Total of 0 licenses in use) Users of mat_designer: (Total of 550 licenses issued; Total of 0 licenses in use) Users of mbseconnector_genesys: (Warning: 25 licenses, future start date) Users of mbseconnector_rhapsody: (Warning: 25 licenses, future start date) Users of mbseconnector_windchill: (Warning: 25 licenses, future start date) Users of mc_level1: (Warning: 25 licenses, future start date) Users of mc_level2: (Warning: 25 licenses, future start date) Users of mc_remoteexecution: (Warning: 50 licenses, future start date) Users of mc_simultaneouswfexecution: (Warning: 200 licenses, future start date) Users of medini_base: (Total of 550 licenses issued; Total of 0 licenses in use) Users of medini_connectivity: (Total of 550 licenses issued; Total of 0 licenses in use) Users of medini_cybersec_level1: (Total of 550 licenses issued; Total of 0 licenses in use) Users of medini_cybersec_level2: (Total of 550 licenses issued; Total of 0 licenses in use) Users of medini_dc_configurator: (Total of 550 licenses issued; Total of 0 licenses in use) Users of medini_safety_level1: (Total of 550 licenses issued; Total of 0 licenses in use) Users of medini_safety_level2: (Total of 550 licenses issued; Total of 0 licenses in use) Users of medini_safety_level3: (Total of 550 licenses issued; Total of 0 licenses in use) Users of motorcad_im: (Total of 550 licenses issued; Total of 0 licenses in use) Users of motorcad_pm: (Total of 550 licenses issued; Total of 0 licenses in use) Users of motorcad_sync: (Total of 550 licenses issued; Total of 0 licenses in use) Users of optislang_level1: (Total of 550 licenses issued; Total of 0 licenses in use) Users of optislang_level2: (Total of 550 licenses issued; Total of 0 licenses in use) Users of optislang_level3: (Total of 550 licenses issued; Total of 0 licenses in use) Users of piautoin: (Total of 550 licenses issued; Total of 0 licenses in use) Users of picatv5: (Total of 550 licenses issued; Total of 0 licenses in use) Users of piproe: (Total of 550 licenses issued; Total of 0 licenses in use) Users of pisoledg: (Total of 550 licenses issued; Total of 0 licenses in use) Users of pisolwor: (Total of 550 licenses issued; Total of 0 licenses in use) Users of piug: (Total of 550 licenses issued; Total of 0 licenses in use) Users of preppost: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rd_ckgraph: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rd_ckpost: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rd_ckpreproc: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rd_ckui: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rd_fortemesh: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rd_forteui: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rd_forteviz: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rd_kineticsapi: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rd_mechforte: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rd_mechmfc: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rd_mechsoot: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rd_mechwb: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rd_reactionwbui: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rdacis: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rdpara: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rocky_preppost: (Total of 550 licenses issued; Total of 0 licenses in use) Users of rocky_solver: (Total of 550 licenses issued; Total of 0 licenses in use) Users of vmotion_catiai: (Total of 550 licenses issued; Total of 0 licenses in use) Users of vmotion_drtrain: (Total of 550 licenses issued; Total of 0 licenses in use) Users of vmotion_drtrain_pre: (Total of 550 licenses issued; Total of 0 licenses in use) Users of vmotion_links: (Total of 550 licenses issued; Total of 0 licenses in use) Users of vmotion_mesh: (Total of 550 licenses issued; Total of 0 licenses in use) Users of vmotion_mesh_pre: (Total of 550 licenses issued; Total of 0 licenses in use) Users of vmotion_para: (Total of 550 licenses issued; Total of 0 licenses in use) Users of vmotion_post: (Total of 550 licenses issued; Total of 0 licenses in use) Users of vmotion_pre: (Total of 550 licenses issued; Total of 0 licenses in use) Users of vmotion_step: (Total of 550 licenses issued; Total of 0 licenses in use) Users of zob_level1: (Total of 550 licenses issued; Total of 0 licenses in use) Users of zob_level2: (Total of 550 licenses issued; Total of 0 licenses in use) Users of zos_level1: (Total of 550 licenses issued; Total of 0 licenses in use) Users of zos_level2: (Total of 550 licenses issued; Total of 0 licenses in use) Users of zos_level3: (Total of 550 licenses issued; Total of 0 licenses in use) Users of Exalto_gds: (Total of 500 licenses issued; Total of 0 licenses in use) Users of explicit_advanced: (Total of 500 licenses issued; Total of 0 licenses in use) Users of GFD_Creator: (Total of 500 licenses issued; Total of 0 licenses in use) Users of granta_sim_mat_data: (Total of 500 licenses issued; Total of 0 licenses in use) Users of Helic_Central: (Total of 500 licenses issued; Total of 0 licenses in use) Users of HelicCentral_ui: (Total of 500 licenses issued; Total of 0 licenses in use) Users of ice_translator: (Total of 500 licenses issued; Total of 0 licenses in use) Users of Mesh_Viewer: (Total of 500 licenses issued; Total of 0 licenses in use) Users of MeshViewer: (Total of 500 licenses issued; Total of 0 licenses in use) Users of motorcad: (Total of 500 licenses issued; Total of 0 licenses in use) Users of nspice_apl: (Total of 500 licenses issued; Total of 0 licenses in use) Users of nspice_hicap: (Total of 500 licenses issued; Total of 0 licenses in use) Users of nspice_sv: (Total of 500 licenses issued; Total of 0 licenses in use) Users of Process_Configurator: (Total of 500 licenses issued; Total of 0 licenses in use) Users of RaptorX: (Total of 500 licenses issued; Total of 0 licenses in use) Users of RaptorX_Booster: (Total of 500 licenses issued; Total of 0 licenses in use) Users of RaptorX_Engine: (Total of 500 licenses issued; Total of 0 licenses in use) Users of rd_ckcompute: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_apl: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_caching: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_gds2def: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_inductance: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_lef2def: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_mpr: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_netlisting: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_passchk: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_pwrcalc: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_sim0: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_sim1: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_sim3: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_spice_pkg: (Total of 500 licenses issued; Total of 0 licenses in use) Users of redhawk_vcd: (Total of 500 licenses issued; Total of 0 licenses in use) Users of RXBackAnnotation: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sherlock: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptArtist: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptDirectDotLib: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptElaborate: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptGAFSplit: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptIPWizard: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptMixedLanguage: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptMixedVT: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptMultipleTestBenches: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptMultipleVoltages: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptPowerGating: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptSOC: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptSPEFCapacitance: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptSynLib2Alf: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptSystemVerilog: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptTBEngine: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptVectorless: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptVectorSelector: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptVWEngine: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptWSEngine: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptWWALFLint: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptWWEngine: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptWWGAF: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptWWSim: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptWWUI: (Total of 500 licenses issued; Total of 0 licenses in use) Users of sptWWVCDPlus: (Total of 500 licenses issued; Total of 0 licenses in use) Users of Tech_Viewer: (Total of 500 licenses issued; Total of 0 licenses in use) Users of Techfile_Converter: (Total of 500 licenses issued; Total of 0 licenses in use) Users of Techfile_Validator: (Total of 500 licenses issued; Total of 0 licenses in use) Users of VeloceAdaptiveCompaction: (Total of 500 licenses issued; Total of 0 licenses in use) Users of VelocePolygonEngine: (Total of 500 licenses issued; Total of 0 licenses in use) Users of VeloceRaptor: (Total of 500 licenses issued; Total of 0 licenses in use) Users of VeloceRaptorX_itk: (Total of 500 licenses issued; Total of 0 licenses in use) Users of VeloceRaptorX_ui: (Total of 500 licenses issued; Total of 0 licenses in use) Users of vmotion: (Total of 500 licenses issued; Total of 0 licenses in use) Users of moxie_sysml: (Warning: 25 licenses, future start date) Users of odtk_level1: (Warning: 25 licenses, future start date) Users of odtk_level2: (Warning: 25 licenses, future start date) Users of stk_data_federate: (Warning: 25 licenses, future start date) Users of stk_engine_runtime: (Warning: 25 licenses, future start date) Users of stk_geodata: (Warning: 25 licenses, future start date) Users of stk_geoserver: (Warning: 50 licenses, future start date) Users of stk_mission_air: (Warning: 25 licenses, future start date) Users of stk_mission_level1: (Warning: 25 licenses, future start date) Users of stk_mission_level2: (Warning: 25 licenses, future start date) Users of stk_mission_level3: (Warning: 25 licenses, future start date) Users of stk_mission_space: (Warning: 25 licenses, future start date) Users of aa_r_hpc: (Error: 256 licenses, unsupported by licensed server) Users of aa_mcad: (Error: 550 licenses, unsupported by licensed server) Users of aa_r: (Error: 50 licenses, unsupported by licensed server) Users of aa_ds: (Error: 500 licenses, unsupported by licensed server) Users of aa_t_a: (Error: 500 licenses, unsupported by licensed server) Users of aim_mp1: (Error: 550 licenses, unsupported by licensed server) ansoftd: UP v11.17.2 Feature usage info: Users of al4allegro: (Error: 550 licenses, unsupported by licensed server) Users of al4ansoft: (Error: 550 licenses, unsupported by licensed server) Users of al4apd: (Error: 550 licenses, unsupported by licensed server) Users of al4boardstation: (Error: 550 licenses, unsupported by licensed server) Users of al4cadvance: (Error: 550 licenses, unsupported by licensed server) Users of al4cds: (Error: 550 licenses, unsupported by licensed server) Users of al4encore: (Error: 550 licenses, unsupported by licensed server) Users of al4expedition: (Error: 550 licenses, unsupported by licensed server) Users of al4first: (Error: 550 licenses, unsupported by licensed server) Users of al4gem: (Error: 550 licenses, unsupported by licensed server) Users of al4generic: (Error: 550 licenses, unsupported by licensed server) Users of al4odb++: (Error: 550 licenses, unsupported by licensed server) Users of al4powerpcb: (Error: 550 licenses, unsupported by licensed server) Users of al4virtuoso: (Error: 550 licenses, unsupported by licensed server) Users of al4zuken: (Error: 550 licenses, unsupported by licensed server) Users of alinks_gui: (Total of 550 licenses issued; Total of 0 licenses in use) Users of ansoft_distrib_engine: (Error: 1100 licenses, unsupported by licensed server) Users of designer_desktop: (Error: 550 licenses, unsupported by licensed server) Users of designer_hspice: (Error: 1100 licenses, unsupported by licensed server) Users of emit_legacy_gui: (Error: 550 licenses, unsupported by licensed server) Users of emit_solve: (Error: 550 licenses, unsupported by licensed server) Users of ensemble_25_sim: (Error: 550 licenses, unsupported by licensed server) Users of ensemble_gui: (Error: 550 licenses, unsupported by licensed server) Users of filter_synthesis: (Error: 550 licenses, unsupported by licensed server) Users of fwspice_export: (Error: 550 licenses, unsupported by licensed server) Users of hfss_desktop: (Error: 550 licenses, unsupported by licensed server) Users of hfss_gui: (Error: 550 licenses, unsupported by licensed server) Users of hfss_solve: (Error: 550 licenses, unsupported by licensed server) Users of hfss_transient_solve: (Error: 1100 licenses, unsupported by licensed server) Users of hfsshpc: (Error: 9056 licenses, unsupported by licensed server) Users of hfssie_gui: (Error: 550 licenses, unsupported by licensed server) Users of hfssie_solve: (Error: 550 licenses, unsupported by licensed server) Users of hfsssbr_solve: (Error: 550 licenses, unsupported by licensed server) Users of m2dfs_gui: (Error: 1100 licenses, unsupported by licensed server) Users of m2dfs_qs_solve: (Error: 550 licenses, unsupported by licensed server) Users of m2dfs_solve: (Error: 1100 licenses, unsupported by licensed server) Users of m3dfs_gui: (Error: 550 licenses, unsupported by licensed server) Users of m3dfs_qs_solve: (Error: 550 licenses, unsupported by licensed server) Users of m3dfs_solve: (Error: 550 licenses, unsupported by licensed server) Users of maxwell_desktop: (Error: 1100 licenses, unsupported by licensed server) Users of maxwlspc: (Error: 550 licenses, unsupported by licensed server) Users of nexxim_ami: (Error: 1100 licenses, unsupported by licensed server) Users of nexxim_dc: (Error: 1650 licenses, unsupported by licensed server) Users of nexxim_eye: (Error: 1100 licenses, unsupported by licensed server) Users of nexxim_gui: (Error: 550 licenses, unsupported by licensed server) Users of nexxim_hb: (Error: 550 licenses, unsupported by licensed server) Users of nexxim_netlist: (Error: 550 licenses, unsupported by licensed server) Users of nexxim_osc: (Error: 550 licenses, unsupported by licensed server) Users of nexxim_tran: (Error: 1650 licenses, unsupported by licensed server) Users of nexxim_tvnoise: (Error: 550 licenses, unsupported by licensed server) Users of optimetrics: (Error: 550 licenses, unsupported by licensed server) Users of pemag: (Total of 550 licenses issued; Total of 0 licenses in use) Users of pexprt: (Total of 550 licenses issued; Total of 0 licenses in use) Users of q3d_desktop: (Error: 550 licenses, unsupported by licensed server) Users of rmxprt_bcm: (Error: 550 licenses, unsupported by licensed server) Users of rmxprt_ecm: (Error: 550 licenses, unsupported by licensed server) Users of rmxprt_gui: (Error: 550 licenses, unsupported by licensed server) Users of rmxprt_im: (Error: 550 licenses, unsupported by licensed server) Users of rmxprt_sym: (Error: 550 licenses, unsupported by licensed server) Users of savant_legacy_gui: (Error: 550 licenses, unsupported by licensed server) Users of si2d_gui: (Error: 1100 licenses, unsupported by licensed server) Users of si2d_solve: (Error: 1100 licenses, unsupported by licensed server) Users of si3d_gui: (Error: 550 licenses, unsupported by licensed server) Users of si3d_solve: (Error: 550 licenses, unsupported by licensed server) Users of simplorer_advanced: (Total of 550 licenses issued; Total of 0 licenses in use) Users of simplorer_control: (Total of 550 licenses issued; Total of 0 licenses in use) Users of simplorer_CProgrInterface: (Total of 550 licenses issued; Total of 0 licenses in use) Users of simplorer_desktop: (Error: 550 licenses, unsupported by licensed server) Users of simplorer_gui: (Total of 550 licenses issued; Total of 0 licenses in use) Users of simplorer_LibSMPS: (Total of 550 licenses issued; Total of 0 licenses in use) Users of simplorer_model_export: (Error: 550 licenses, unsupported by licensed server) Users of simplorer_modelica: (Error: 550 licenses, unsupported by licensed server) Users of simplorer_sim: (Total of 550 licenses issued; Total of 0 licenses in use) Users of simplorer_sim_entry: (Total of 550 licenses issued; Total of 0 licenses in use) Users of simplorer_vhdlams: (Total of 550 licenses issued; Total of 0 licenses in use) Users of SimplorerBasic: (Error: 550 licenses, unsupported by licensed server) Users of siwave_gui: (Error: 550 licenses, unsupported by licensed server) Users of siwave_level1: (Total of 550 licenses issued; Total of 0 licenses in use) Users of siwave_level2: (Error: 550 licenses, unsupported by licensed server) Users of siwave_level3: (Error: 550 licenses, unsupported by licensed server) Users of siwave_reporter: (Error: 550 licenses, unsupported by licensed server) Users of siwave_solver: (Error: 550 licenses, unsupported by licensed server) Users of symphony_dt_sim: (Error: 550 licenses, unsupported by licensed server) Users of symphony_fd_sim: (Error: 550 licenses, unsupported by licensed server) Users of xlate_catia4: (Error: 550 licenses, unsupported by licensed server) Users of xlate_catia5: (Error: 550 licenses, unsupported by licensed server) Users of xlate_iges: (Error: 550 licenses, unsupported by licensed server) Users of xlate_inventor: (Error: 550 licenses, unsupported by licensed server) Users of xlate_parasolid: (Error: 550 licenses, unsupported by licensed server) Users of xlate_proe: (Error: 550 licenses, unsupported by licensed server) Users of xlate_solidworks: (Error: 550 licenses, unsupported by licensed server) Users of xlate_step: (Error: 550 licenses, unsupported by licensed server) Users of xlate_unigraphics: (Error: 550 licenses, unsupported by licensed server) -
July 19, 2023 at 3:21 pm
ANSYS_MMadore
Forum ModeratorPlease note this message with the STK licenses: Warning: 25 licenses, future start date. That explains why you cannot access the licenses, they haven't started yet. You can contact your Ansys Account Manager if you feel this is in error and they should be active now.
July 19, 2023 at 3:22 pm
curtis.fox
SubscriberHi there,
  Will check with CEAS IT about the licenses.Â
  Thanks for the help.
July 19, 2023 at 3:27 pm
July 19, 2023 at 3:51 pm
ANSYS_MMadore
Forum ModeratorIf you look in those INCREMENTs you will see START=01-aug-2023.
Please contact your Ansys Account Manager about revising the Start date, if it's possible.
July 19, 2023 at 3:58 pm
curtis.fox
SubscriberWill look into it.
Thanks.
- The topic ‘A current stk license could not be found.’ is closed to new replies.
5824
