Ansys Products
Ansys Products
(-96,7:11001 “WinSock: Host not found (HOST_NOT_FOUND)”)
    • Pol
      i have followed this steps:
      1.2. Using the Ansys Client Settings Utility
      But i get that error in the laptop when i try to activated the license. I have already install Ansys in the License Server PC and it's working properly
      The error is:
      Imutil - Copyright (c) 1989-2019 Flexera. All Rights Reversed. Flexible License Manager status on Thu 11/25/2021 12:11 [Detecting lmgrd processes...] Error getting status: License server machine is down or not responding. (-96,7:11001 "WinSock: Host not found (HOST_NOT_FOUND)") Error: Command failed C: Program FilesANSYS Studentv212licensingclientwinx64Imuril.exe lmstat - c PORT [email protected] NAME
    • George Karnos
      The message indicates "HOST_NOT_FOUND" which typically appears if the ip address and hostname do not resolve properly on the client machine. You can try adding an entry to your client machine in the C:\Windows\System32\drivers\etc\hosts file for the ip and hostname of the license server
      Example:
      123.45.6.78 license-ansys
    • Pol
      Hi, I followed all the new steps and now the new error has appeared when i try to activated the license in the teammates computer.
      The error is:
      lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved. Flexible License Manager status on Tue 11/30/2021 19:33 [Detecting lmgrd processes...] Error getting status: Cannot connect to license server system. (-15,10032) Error: Command failed: D:\Program Files\ANSYS Inc\ANSYS Student\v212\licensingclient\winx64\lmutil.exe lmstat -c PORTNAME@HOSTNAME
    • mourad.berday
      duré de connexion maximal de connexion passe lors de la lecture .......
  • The topic ‘(-96,7:11001 “WinSock: Host not found (HOST_NOT_FOUND)”)’ is closed to new replies.
