February 6, 2021 at 1:33 pmAbelBerhanemeskelSubscriber
Hi Everyone,
I was trying to model the initial imperfection using the eigenvalue buckling mode shape but I got confused about the scale factor. Is the scale factor the amplitude at the maximum buckled shape of the chosen mode? or should we just let the scale factor be 1? If the scale factor is indeed the amplitude does our choice of units come into consideration when we are applying it?
Thanks
February 8, 2021 at 12:32 pmAshish KhemkaForum ModeratornnPlease refer to the following excerpt from the Ansys Help (https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v201/en/wb_sim/ds_geo_from_def.html)nScale Factor: this property scales the displacements of the initial configuration. If Scale Factor is 1.0, the full displacement value will be added to each node, 0.5, half the displacement value will be added, and so on. Negative Scale Factor values subtract the displacements and reverse the direction of deformation.nRegards,nAshish KhemkanViewing 1 reply thread- The topic ‘Initial Imperfection and scale factor’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- How to apply Compression-only Support?
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Geometric stiffness matrix for solid elements
- Script Error Code:800a000d
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
- BackGround Color
Top Contributors-
1562
602
599
591
366
