Ansys Products
Ansys Products
Error installing Ansys ElectroMagnetic with certain version
    • tuevu
      My school cluster recently upgrade from Oracle Linux to CentOS8, and it caused severe problem while installing Ansys ElectroMagnetic to this new system.
      In particular, for the Ansys version 19.0, 19.2, 19.5, the installation of Electronics throw Java issue error when running with GUI. Please see image
    • Matt Madore
      CentOS8 is not supported. You can try setting the variable ANS_IGNOREOS=1 before installation, but you are likely to encounter problems with libraries when trying to run. You can find our supported platforms lists on this page.nhttps://www.ansys.com/solutions/solutions-by-role/it-professionals/platform-supportnnThanks,nMattn
    • tuevu
      Thank you for your fast response. However the variable setting ANS_IGNOREOS=1 does not help. Same error occurs for Electronics.nWhen I read the table from the provided link, here is what I found. I want to use Maxwell from AnsysEM with CentOS8 and it has all the tickmarks here. Does it mean supported OS or not?nInn
    • Matt Madore
      I've reached out separately on the issue.n
  • The topic ‘Error installing Ansys ElectroMagnetic with certain version’ is closed to new replies.
