January 18, 2021 at 2:29 pmAidan_JSubscriber
I am running Ansys Discovery AIM on a sever based license (Formula student, 5 sponsored licenses distributed by tunnelling into central computer). The tunnelling software is PuTTY, however during a CFD simulation my internet dropped out and my connection to the licensing computer failed. This is not uncommon however this time I failed to restart the connection before the 1h grace period expired. Once this had happened, I tried to close AIM, and it became unresponsive. After a couple of hours I decided to close it forcefully via the "program is unresponsive" dialogue.
Ansys AIM now is unable to open at all, opening straight to an unresponsive page despite restarting my PC, as shown below. This screen persists indefinitely and clicking on anything brings up the same "program is unresponsive" dialogue.
Other Ansys products which rely on the same license, such as Spaceclaim still work just fine, so the licensing still works fine
January 18, 2021 at 6:35 pmANSYS_MMadoreAnsys EmployeeArray Please try renaming these 2 directories by adding a .BACK to the end?nC:\Users\USERNAME\AppData\Roaming\Ansys\v195nC:\Users\USERNAME\AppData\Roaming\DiscoverynnThank you,nMattnJanuary 18, 2021 at 11:07 pmAidan_JSubscriberAbsolutely spot on, worked first time! thankyou very much indeed,nAidannJanuary 23, 2021 at 1:21 pmAidan_JSubscriberArray Sorry to bother you again, but since trying that fix it has become apparent that the changes made have made ansys highly unstable and it is now unable to perform any tasks, all meshes, physics solutions and results renderings result in immediate failure of the task at best, and a crash resembling the initial one at worst (opening to an unresponsive page). I have even had AIM crash with no input at all, just transitioning gradually from normal cursor to cursor with processing icon to just processing icon to unresponsive. Below are a couple of the error messages I managed to capture before it became unresponsive:nIt should be noted that I did not have a directory at C:\Users\USERNAME\AppData\Roaming\Discovery at all, only the \Ansys\v195 one and as such i only renamed the v195 directory.nAny thoughts as to what might have gone wrong?nMany thanks and apologies for the inconvenience,nAidannJanuary 25, 2021 at 2:15 pmANSYS_MMadoreAnsys EmployeeArray renaming the C:\Users\USERNAME\AppData\Roaming\Ansys\v195 would not cause these errors, it simply removes all previous settings applied to bring back to a fresh environment. You can easily undo this change by deleting the newly created C:\Users\USERNAME\AppData\Roaming\Ansys\v195 and then renaming the C:\Users\USERNAME\AppData\Roaming\Ansys\v195.BACK to v195.nHave you attempted to install a newer version?nFebruary 7, 2021 at 2:20 pmAidan_JSubscriberthanks a lot that makes sense to me!nCurrently im running Ansys Discovery AIM 2019 R3, on the website it shows that the latest release is Ansys 2021 R1 but it makes no mention of AIM within that, does the 2021 R1 verison extend to AIM as well?nFebruary 8, 2021 at 2:32 pmANSYS_MMadoreAnsys EmployeeFor Discovery AIM, please install 2020R2.nFebruary 21, 2021 at 2:16 pmAidan_JSubscriberThanks a lot that's very helpful, do you know where this can be downloaded from? On the website I can only find download links for Ansys Discovery 2021 R1, is there a location with older versions avaliable?nFebruary 22, 2021 at 4:57 pmANSYS_MMadoreAnsys EmployeeArray Please see it under Prior ReleasesnMarch 1, 2021 at 12:34 pmANSYS_MMadoreAnsys Employeewww.ansys.com/studentnViewing 10 reply threads- The topic ‘Ansys AIM unable to open following license error’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Workbench license error
- Unexpected error on Workbench: Root element not found.
- Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
- Questions and recommendations: Septum Horn Antenna
- AQWA: Hydrodynamic response error
- Tutorial or Help for 2 way FSI
- Moment Reaction probe with Large deformation
- 2 way coupled FSI for ball bearing
- Ansys with Vmware and CPU configuration : I’m lost, good practice?
- Ball Bearing Transient Structural
Top Contributors-
1316
591
569
525
366
Please Login to Report Topic
Please Login to Share Feed
