July 31, 2020 at 5:26 pm
prajput
Ansys EmployeeI have a 4 layer PCB, do I need to create a single via or a via array for isolation?
July 31, 2020 at 5:27 pm
Charlotte Blair
Ansys EmployeeHello,
That's all depends on the operating frequency. At low frequency, a single ground via may be sufficient to keep ground as ground but as you go higher in the frequency you may need to create a via fence to keep the signal isolated from other parasitics.
July 31, 2020 at 5:28 pm
prajput
Ansys EmployeeThank you for the response.
How much space should I put between the vias then?
Charlotte Blair
Ansys EmployeeHi - The rule of thumb is lambda/20 but it depends on your application.
July 31, 2020 at 5:29 pm
prajput
Ansys EmployeeIf I have to consider the fourth harmonic should I decrease the spacing?
July 31, 2020 at 5:30 pm
rtk
Ansys EmployeeIn addition to the above responses, depending on which harmonic you are concerned about will dictate the spacing. From the RF/microwave perspective, more ground vias are better.Â
Viewing 5 reply threads
- The topic ‘Via creation in PCB’ is closed to new replies.
1309
