流体
流体
Please help me check if there are any issues with the UDF.
    • 24212040751
      The paper I referred to is:
      Xu W, Dong CJ, Li DS. Numerical simulation on influences of wind speed to leaking diffusion of liquid ammonia. Advanced Materials Research. 2015 Jan 27;1073:383-7.
      #include "udf.h"
      #define T_evap -33.0   // Evaporation temperature in Celsius
      DEFINE_PROPERTY(gasification_model, c, t)
          real T_d = C_T(c, t);  // Temperature of the droplet
          real T_env = C_T(c, t); // Temperature of the surrounding environment
          real m_d = C_MASS(c, t); // Mass of the droplet
          real c_d = 2.0;  // Specific heat of the droplet (example value)
          real A_d = 0.1;  // Surface area of the droplet (example value)
          real h = 1000.0; // Heat transfer coefficient (example value)
          real h_latent = 2260.0; // Latent heat of vaporization for ammonia (J/g)
          // Check if the droplet is in the liquid phase (T_d < T_evap)
          if (T_d < T_evap) {
              // Liquid phase: Apply heat transfer equation
              return h * A_d * (T_env - T_d) / (m_d * c_d);
          else {
              // Gas phase: Apply phase change equation with latent heat
              return h * A_d * (T_d - T_env) / (m_d * c_d) + h_latent;
      DEFINE_DPM_FORCE(droplet_force, f, t, c, dt)
          real u = C_U(c,t); // Velocity of the droplet
          real v = C_V(c,t); // Velocity of the droplet
          real w = C_W(c,t); // Velocity of the droplet
          real gravity = 9.81; // Acceleration due to gravity
          real drag_force = calculate_drag_force(u, v, w); // Call function for drag force calculation
          // Additional forces like Brownian, added mass can be defined here
          return drag_force + gravity;
      See comments  https://innovationspace.ansys.com/forum/forums/topic/compile-the-udf-code-and-apply-it-to-the-dpm/
      What is the DPM_FORCE for as gravity & flow are already included by default.
  • 您必须登录才能回复此主题。
