May 13, 2020 at 4:09 pm
May 13, 2020 at 6:37 pmAmine Ben Hadj AliAnsys EmployeeWas the interpretation successful? Which version?
May 13, 2020 at 10:48 pm
May 14, 2020 at 5:07 amAmine Ben Hadj AliAnsys EmployeeTry compiling the udf.
May 16, 2020 at 1:47 amANSYSCOMPSubscriber
I tried to compile my udf's code according to UDF MANUAL. Unfortunately, the program has encountered the following problems.
I had configured VS2012 to become accessible from fluent 2017
1. Define>>>User Defined>>>Functions>>>Compiled
2. ADD UDF code
2. For header files (.h), Could you please verify it, if it is correct or not.
#include "udf.h"
DEFINE_DPM_BODY_FORCE(particle_body_force,d,i).
3. Build>>>ok
4. Load>>error
Viewing 4 reply threads
- The topic ‘Missing ::libudf for hooking udf code of body force profile’ is closed to new replies.
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Script Error
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
823
599
591
366
