Ansys Products
Ansys Products
Ansys License Manager doesn’t Work
    • darrenshann
      Right now I want to create a demo system which is running in Linux and AMD system.
      All the Ansys SW already installed, but when try to apply demo license provided by Ansys team, the license won't applied.
      I did re-run License Manager Installation, and comes with attached error:
      What I did backed up share _file and remove it and after that re-applied.
      and re-run the License Manager GUI still the same error.
      Opening the localhost1084 still have no GUI appear.
      Kindly help to resolve this, don't know if we have to re-install the license manager or un-install the whole things..
    • tsiriaks
      Please post the content of attachment inline with text as ANSYS employees are not allowed to download them.
      If you can't open up the ANSYS License Management Center, you can still control ANSYS License Manager with command lines.
      1. Place your license file in /ansys_inc/shared_files/licensing/license_files/  and make sure its extension is .lic
      2. start/stop license manager by using the following commands
      /ansys_inc/shared_files/licensing/start_ansysli
      /ansys_inc/shared_files/licensing/stop_ansysli
    • darrenshann
      This worked.. thanks..
    • tsiriaks
      That's good to hear !
      Thank you for the update.
      Please mark the post as 'Is Solution' so we know there is a resolution for this.
      Thanks,
      Win
  • The topic ‘Ansys License Manager doesn’t Work’ is closed to new replies.
