March 25, 2025 at 3:09 pm
eng_m_m.abd89
SubscriberHello,
I am writing a UDF to reflect a gas generation model of battery components. I have 10 chemical reactions, and I can define the reaction rate of reactants using the Arrhenius equation. But how to model the total number of moles of gases generated from these chemical reactions?attached is the table of the reaction rates. I assume I can calculate the generated number of moles for specific species such as (CO2) for example using the below equation
Generation rate = sum of (stoichiometric coefficient x reaction rate)
amount of species = accumulated generation rate x volume
Any suggestions or recommendations will be very helpful.
March 25, 2025 at 3:39 pm
Forum ModeratorIf all reactions are Arrhenius rate based why not just use the Fluent species models without UDFs?Â
March 25, 2025 at 3:42 pm
eng_m_m.abd89
SubscriberHey Rob,Â
Thanks for answering. I thought about it; I am validating a paper, and they did UDF. I think they used the UDF, because this gas generation model links two other models, which are heat generation within the battery, and then the gas vent.
Mahmoud
March 25, 2025 at 3:52 pm
Forum ModeratorThen you may need to review the source term macros for the gas generation.Â
- How do I get my hands on Ansys Rocky DEM
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- convergence issue for transonic flow
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- Point exception in erosion calculation
- Script Error Ansys
- Errors with multi-connected bodies using AQWA
- Quantitative results
2738
959
824
599
591
