TURBOGRID NOT WORKING
    • enrmarvil
      Hello everyone,
      I´m using Turbogrid to generate a mesh on centrigual compressor, and it worked until now, I create a model using Bladegen and then import these data to Turbogrid module, but it beggin to give me errors when i started run Turbogrid, I´ve atached an image of the message it gives me.
      Also apears me another message, when i click in Turbogrid module:
      And also this:
      All that wasn´t happened before, three days ago i can run turbogrid without problems.
      I will be so gratefull if you can help me with these,
      thanku everyone,
      Kike.
    • Rajeshwari Jadhav
      Hi Kike,
      Is this a free student version or academic? If academic then check though licensing settings if it's pointing to correct server.
