February 20, 2025 at 7:42 pm
f.jalilijamshidian
SubscriberHi. Is it possible to apply constant heat on the external surface of a cylinder (wall) containing particles in Rocky (fluidized bed)?
Thank you.
February 21, 2025 at 3:01 pm
Lucas Bertollo Baggio
Ansys EmployeeHello,
You can set this heat source in the Fluent .cas file for a 2-way coupled project.
February 21, 2025 at 3:48 pm
f.jalilijamshidian
SubscriberThanks Lucas,
So is it automatically applied in Rocky? Should not I use any other external modules in Rocky?
I appreciate that.
February 21, 2025 at 4:07 pm
Ansys EmployeeYou just have to Enable Thermal in Study | Physics. No additional modules required.Â
February 21, 2025 at 4:12 pm
f.jalilijamshidian
SubscriberThank you so much Lucas.
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Script Error
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
- Errors with multi-connected bodies using AQWA
897
599
591
444
