February 14, 2025 at 9:57 am
Jee Loong Hee
SubscriberHello,
I am currently learning from the tutorial for Porous media before implementing the 'same' strategy for cylindrical packed bed.Â
I have checked the tutorial for Porous Media and there was an example for a catalytic converter (for gas exhaust). I do not quite understand, why is the material for porous media is 'selected' as 'nitrogen' in the drop-down material menu of fluid:substrate1 and fluid:substrate:2 (in tutorial: Chapter 3: Modeling Flow Through Porous Media)?
Shouldn't that be platinum, etc? If say a metal catalyst material is selected, what would happen to the modelling result? Does it means that the inlet gas (which is nitrogen) must match the porous media (material?).
For my question no.2, I could see that for porous media, the ANSYS tutorial opt for laminar zone for the porous media, since the inlet velocity is 125 m/s, the idea of setting laminar zone is to stabilise the flow regime within the porous media (assumption) making the solver stable?
Thanks
Jee -
February 14, 2025 at 10:17 am
Jee Loong Hee
SubscriberÂ
Oh, please forgive my silly question. I understood it now. So only in the heat transfer (energy problem) that the material of the porous media matters, which can be selected in the thermal model (in POROUS tab).Â
February 14, 2025 at 10:24 am
Forum ModeratorNot a problem, if you don't know and then learn something it's not a silly question. The gas/liquid material is the flowing fluid (air/nitrogen/mixture) and the "solid" bit may well be platinum or wool (don't ask) should you need to account for enhanced conduction in the zone.Â
- How do I get my hands on Ansys Rocky DEM
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Script Error
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
- Errors with multi-connected bodies using AQWA
1992
897
599
591
418
