January 27, 2025 at 6:38 pmwalaakm10Subscriber
Hello everyone, I am trying to make an inflation on certain walls for the near investigation. I need to avoid the high computational cost, so I chose to insert inflation into the determined walls. When I select one wall and select insert>> inflation, when I press "Apply" to the boundaries, it keeps saying that (no selection), and when I ignore it and press "Generate," the inflation is not created, and ANSYS tells me, "Please define a boundary for the inflation control.". Would anyone help me to fix this? Here are screenshots for the steps.Â
January 28, 2025 at 10:56 amCFD_FriendAnsys Employee
Hi walaakm10,
I think there is a confusion of terminology. I assume that you want inflation layers growing from a face into the domain. If this is the case, then under Scope->Geometry you should choose the full body and not the face. Then under Definition-> Boundary, you should choose the face.Â
In your screenshots, I can see that for geometry, you have chosen face, and now it is asking for boundary. Boundary in this case will be an edge. Inflation then grows on that face alone, from an edge, which I assume is not what you intend.
Note: Pressing Ctrl+B, you can select bodies, and by pressing Ctrl+F, you can select faces.
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- Script Error
- convergence issue for transonic flow
- RIBBON WINDOW DISAPPEARED
- Running ANSYS Fluent on a HPC Cluster
1772
635
599
591
366
