December 8, 2024 at 1:49 am
dhs22
SubscriberHello everyone,
I am trying to create an airfoil mesh (multiblock and structured) in ICEM CFD with somewhat unconventional target spacings. Specifically, I need the streamwise spacing (dx) on the upper surface like the followings:- constant spacing between x/c=0.1Â and x/c=0.2,Â
- increase spacings linearly up to x/c=0.2 to x/c=0.6
- constant spacing again between x/c=0.6 and x/c=1.0.
I understand that this can be easily achieved by splitting the blocks (block -1 in the figure), but my question is: are there any alternatives I can try without splitting the blocks? Thank you!
December 11, 2024 at 8:07 am
Essence
Ansys EmployeeHello,
If you need hexahedral mesh without using blocking, I would suggest you to use Ansys/Workbench Meshing which can do the work.
1494
1376
1209
