November 21, 2024 at 6:40 pm
abu.hamad
SubscriberHi, I am performing static angle of repose tutorial available in rocky (dem_tut02_files). In the Post processing when i run the Pre-script code which is given in tutorial files, there is following error which can be seen in the attached figure (error: unknown particle grid function). I do everything same such as its mentioned in tutorial guide but it has error. In addition, i dont know posting here is called "create ticket" or its somewhere else. Actually, i want to to attach error report also but here i am not able to do this. I will be thankful if you can solve my issue. Thanks
November 27, 2024 at 12:46 pm
Jackson Gomes
Ansys EmployeeHello, Abu.hamad
Make sure you are using the last version of the script. Please go to Current Release , select the release version and download the additional package on Add-On Packages.
Best Regards.
5944
1307
