November 7, 2024 at 3:31 pm
suruchi.bala
SubscriberHi,
How to overlap the structure of waveguide with the EF mode profile generated through field profile monitor?
I want to show the structure and mode profile all together in the same plot. Is there a direct option?
November 7, 2024 at 7:24 pm
Guilin Sun
Ansys EmployeeIf this is FDE, you can choose the option:
for FDTD, there is a simple example: https://optics.ansys.com/hc/en-us/articles/360034395154-Tip-for-adding-structure-outlines-to-field-plots
You may also try to plot contours without structure:https://optics.ansys.com/hc/en-us/articles/360045175973-getcontour-Script-command
Or you may use other 3rd party to have better visual effect.
November 7, 2024 at 7:44 pm
suruchi.bala
SubscriberSure, thank you.
1698
1387
1248
