Ansys Products
Ansys Products
Workbench contents blurry on a 4k monitor
    • v.venugopal
      Dear Support,
      I have ansys products 2024R2 installed on a HP laptop. This is a windows 10 machine.
      I connected a new HP 4K monitor (HP Series 7 Pro 27 inch 4K Thunderbolt 4 Monitor - 727pk) to this laptop last week and since then i am happy difficuties in viewing contents of the ansys workbench or any other modules. I tried with the solutions given to change the DPI, e.g.,
      1.Change the High DPI settings under compatibility settings." Properties of workbench > Compatibility > Click on Override high DPI scaling "
      2. Change the "Scaling performed by" option to "System(Enhanced)"
      But not has worked for me so far. This issue is hindering the work progress. Any help please?
      Thanks
      Venki
    • Rajeshwari Jadhav
      Hi Venki,
      Change the display resolution of affected system to check if that helps.
      Goto Start menu> Display settings> Scale and Layout. Try to change these options and check if any of it works for workbench.
      if above method doesn't work try the below options too.
      Can you set below environment variable under system variable
      MECH_BROWSER_USE_AUTO_SCALING="1"
      If that doesn't work and makes the scripting view too small. Please try updating the DPI settings for the Mechanical process, as suggested here for Workbench process.
      General Workbench Issues (ansys.com)
    • v.venugopal
      Hi Rajeshwari,
      I tried all the options you've suggested and nothing appear to help. All other tools and third part software works nicely with this 4k monitor except Ansys.
      Thanks
      Venki
    • Rajeshwari Jadhav
      For which .exe you are changing the DPI settings?
    • v.venugopal
      Hi Rajeshwari,
      using Workbench 2024 R2. Please see below. Thanks.
    • Rajeshwari Jadhav
      Please try the DPI settings on AnsysFWW.exe, right-click workbench shortcut and open file location it will point you to runwb2.exe above that AnsysFWW.exe is located.
    • v.venugopal
      I am sorry to say that none of the above solutions suggested worked. I have even reinstalled ansys and tried.
      Thanks
    • v.venugopal
      Please see a screenshot. Please note the difference in sharpness in text.
    • v.venugopal
      Following the above, opening the Ansys aqwa toolbox, cuts down the work window. please see an image attached. I have tried applying DPI settings to AnsysFWW.exx, RunWB2.exe and even on workbench 2024 R2.exe and all show the same.
      Removing the DPI setting, atleast brings back the full window in Aqwa but resulting in blurry view. The animation is so worst and very poor quality.
    • sohrab
      Hi, I have the same problem with 4k monitor. The texts are so tiny that I cannot work with it and I tried all of the above. changing DPI setting only fixes the bluriness not the tiny tiny menu fonts. Ansys font size problem with 4k monitor
Viewing 9 reply threads
