August 28, 2024 at 6:16 amitoito405231Subscriber
Maxwellで一定磁場を用いて解析を行っております.それに際して,一定磁場を印可する方法として,コイルや永久磁石を配置して行うものしか知りません.しかし,コイルや磁石であると距離によって減衰したりするのが嫌なので,ボックス内で一定の磁場を印可する方法がないか模索しています.前にそういった方法があると聞いたことがあります.よろしくお願いいたします.
August 28, 2024 at 7:08 amErik KostsonAnsys Employee
Also I would suggest to post this in the electronics forum if it is about Maxwell.
All the best
ErikPS in 3D maxwell it is easy to impose a contstant external field, in 2D we need to use vector potential.
Post in the electronics forum for more help
https://www.youtube.com/watch?v=tjqxn3a29JU
- The topic ‘Maxwellでの一定磁場印可の方法について’ is closed to new replies.
Ansys Innovation Space
- How to apply Compression-only Support?
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Image to file in Mechanical is bugged and does not show text
- Element has excessive thickness change, distortion, is turning inside out
635
599
591
366
