July 5, 2024 at 1:01 pm
issacdktn
SubscriberHello everyone,
I've carried out hydrodynamic analyses in Aqwa and would like to use the "time domaine pressure output" I've calculated on the structure to determine the stresses on the structure. As the load varies with time, I would logically like to carry out a dynamic analysis. I don't know which module to use or how to set up the solution.Â
Could you please help me?
July 31, 2024 at 8:28 am
Mike Pettit
Ansys EmployeeHello,
The Hydrodynamic Pressure add-on in Ansys Mechanical is designed exactly for this. The add-on reads the pressures which have been calculated by Aqwa over the hydrodynamic mesh, and maps them on to the selected surfaces of the structural model. We can also map connection loads (cable tensions, joint reactions and tether loads) as well as Morison element loads (new in Release 2024 R2) from a time domain Hydrodynamic Response analysis.
It is only possible to transfer pressures from Aqwa to a Static Structural analysis; we do not support Transient Structural yet, though this may be introduced in the future. The time steps of the hydrodynamic analysis are considered as independent load steps in the structural analysis.
Now that the online help is publically available, I can point you to the relevant section of the Aqwa User Manual, which explains how to set up the workflow: 8.1.3. Setting up your Workflow in Workbench (ansys.com)
I hope this helps!
Mike
- The topic ‘From Aqwa to Dynamic analysis’ is closed to new replies.
- How do I get my hands on Ansys Rocky DEM
- Script Error
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- convergence issue for transonic flow
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- Point exception in erosion calculation
- Errors with multi-connected bodies using AQWA
- Script Error Ansys
2407
930
599
591
569
