May 5, 2024 at 3:08 pm
May 6, 2024 at 12:19 pmLucas Bertollo BaggioAnsys Employee
Hello Kiran,
I suggest that you check the PSD (particle size distribution) for both cases and compare the Material and Material Interaction properties before taking another step.
Kind regards,Â
Lucas
- The topic ‘Comparison: Accumulation height’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Fluent fails with Intel MPI protocol on 2 nodes
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Cyclone (Stairmand) simulation using RSM
- error udf
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- UDF, Fluent: Access count of iterations for “Steady Statistics”
599
591
565
366
