March 17, 2024 at 1:53 amamahar3Subscriber
Hi. I wanted to do the simulation of bonding two small polymer plates by heating the plates near the glass transition temperature and applying external pressure from all sides. The simulation also need to show air bubbles entrapped between the bonding interfaces because of insufficient applied pressure. Is it possible to do this simulation in ansys? Any suggestions would be highly appreciated. Thanks.
March 20, 2024 at 11:52 amSupreetha JForum Moderator
Hello Anish,
Kindly refer to this Forum discussion Simulation of bonding two polymer plates (ansys.com)
I hope this helps.Thank you.
- The topic ‘Regarding simulation of bonding two polymer plates’ is closed to new replies.
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- Script Error
- convergence issue for transonic flow
- RIBBON WINDOW DISAPPEARED
- Running ANSYS Fluent on a HPC Cluster
635
599
591
366
