Electronics
Electronics
Export a material from Maxwell to Fluent
    • Krisztián Szabó
      Hello, what is the easiest way to export material from Maxwell 3-D to Fluent?
      I am working on the heating of a transformer, I want to simulate the flow and I want the materials to be the same.
      Thank you very much!
    • Ivonne Marti
      Hello Krisztián,
      Maxwell materials look at the electromagnetic characteristics and the materials in Fluent to the fluid-dynamic ones. This is the reason why the materials are not shared between both tools and why the input characteristics are different.
      Since each tool has his own material library, you can try to choose same materials and re-write the common characteristics to be the same.
      I hope this helps. Ivonne
  • The topic ‘Export a material from Maxwell to Fluent’ is closed to new replies.
