February 4, 2024 at 11:13 pm
Fady Elshazly
SubscriberHello,
I am working on a model in LSDYNA that goes through dynamic relaxation followed by a transient analysis. How can I run the dynamic relaxation once and then used its results to be applied to the transient analysis directly without the need to run both again each time I solve the model.Â
ThanksÂ
February 5, 2024 at 2:38 pm
Alex Rycman
Ansys EmployeeHello,Â
To restart a simulation after DR phase you can submit a small restart using the d3dump written at the conclusion of the DR phase.Â
Please look at this tutorial about restart using LS-DYNA: https://ftp.lstc.com/anonymous/outgoing/jday/restart.pdf
Alex.Â
February 5, 2024 at 11:21 pm
Fady Elshazly
SubscriberThanks for providing that valuable source. When I try to restart after the dynamic relaxation, the final output does not have a d3plot file to be opened in lsprepost. Is there a way to generate that?
Thanks
February 7, 2024 at 12:39 am
Ushnish Basu
Ansys EmployeeThe restart uses the d3dump file. If you want to make changes to the model, e.g. add or remove parts for the transient analysis, you can use full-deck restart
February 7, 2024 at 5:16 am
Fady Elshazly
SubscriberI am using small restart but the restart process does not generate a d3plot file. it provides d3plot01,d3plot02.... but not the d3plot file.Â
ThanksÂ
February 7, 2024 at 5:26 am
Ushnish Basu
Ansys EmployeeFor small restart the d3plot is from the initial run
February 7, 2024 at 5:28 am
Fady Elshazly
SubscriberGreat, thanks for clarification.Â
Rgards
- The topic ‘LS_DYNA DYNAMIC RELAXATION’ is closed to new replies.
5289
1885
1403
1268
