February 1, 2024 at 9:57 am
Brandon Schroder
SubscriberHi,
I've recently updated from 2022 R1 to 2024 R1 and I've noticed that CFX's solver has become considerably slower in terms of starting, solving and saving a simulation. For example, a simulation of a domain with 200k cells takes 5 minutes to perform 3 iterations and thats with 36 cores. Have there been any changes to the default settings in CFX PRE that I might be unaware of that may have caused this? If not could someone please assist in troubleshooting.Â
February 1, 2024 at 11:53 am
V.P
Ansys EmployeeHi Brandon,
Can you go through the material and see if this helps?
February 1, 2024 at 12:24 pm
Brandon Schroder
SubscriberThanks for the speedy response, much appreciated.
Serial calculation's wall clock shows 2.253 sec, and 36 core parallel is 1.368 sec equating to an efficiency of 4.57% so something is definitely wrong with the setup, which is strange since I had no issues with 2022 R1 and Fluent 2024 R1 seems to be doing just fine in parallel. I'll carry on going through the documentation you've listed.
- The topic ‘CFX 2024 R1 Solver Slow’ is closed to new replies.
4858
1587
1386
1242
