Ansys Products
Ansys Products
DOWNLOAD ANSYS 18.2
    • rabi27
      Hi, is there anyway i can get the ansys student version 18.2? because under prior release there is not option for this
    • tsiriaks
      Hi rabi27 ,
      Any specific reason why you need ANSYS Student version 18.2 ?
      We always recommend to use the most recent version if it applies to your situation.
      Thanks,
      Win
    • delsond
      Hello I also need version 2018, our professor insisted that we use 2018 so we can follow our lab exactly in the class, due to some features moving around in later version.
      May I please have the link to ansys student version 18.2?
      thank you.
      The Student version is 2019R3, you may be able to use the campus network and run R18.2 from there on your own machine. If that's the case University IT will need to help with the port configuration and software downloads.
      Edit. To add, that will get you the Teaching version which the University licence. The (free) Student version is separate but has much the same functionality & limitations.
    • jackgibeau
      I am also trying to get the linux iso's for ansys 18.2 so some work can be extended based on a previous project. Using a newer version is giving different results. On the main site they only offer links to the 2019 and 2020 versions.
      Main site goes back to R19.0 ,  the support team may be able to find an older version.  Please ask the University ASC to raise a support query.
Viewing 5 reply threads
  • The topic ‘DOWNLOAD ANSYS 18.2’ is closed to new replies.
