October 25, 2023 at 11:12 amSwarup TripathySubscriber
Hi
I am fairly new to Ansys Maxwell and I have followed some tutorials too. I wanted to simulate eddy current on a copper conductive disc by giving rotation or linear motion to a NdFe35 permanent magnet. I came across this feed how-to-simulate-eddy-current-loss-in-permanent-magnet, but it displays using 'Transient Analysis', which in my case is not supported in a student license. Is there any other way I could implement this to observe the magnitude of eddy current being generated by changing parameters like the distance and speed of the permanent magnet from the disc?
October 26, 2023 at 12:19 pmTimosAnsys Employee
Hello, unfortunately you cannot observe the eddy currents by a magnet's motion without the Magnetic Transient Solver. You can change the distance in a paramtric run but this will not lead to eddy currents (you need motion). However there is another option to use Eddy Current solver that computes the oscillating magnetic field (causing eddy currents) that exists in a structure given a distribution of AC currents.
- The topic ‘Eddy current induced by a Permanent Magnet on a Cu Disc? [Student software]’ is closed to new replies.
- HFSS Incident Plane Wave excitement mode
- Simulation of capacitor combining eddy currents with displacement currents
- How to calculate eddy and hysteresis losses of the core?
- Ansys Maxwell 3D – eddy current
- How to determine initial position in motion setup
- dq graph non-conformity
- How to customize pulse waveform and injection site in microstrip array
- 180 Degree Phase Shift When Measuring S21
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Parametrizing coil “terminals” with coil geometry
1316
591
569
525
366
