October 20, 2023 at 7:55 pm
October 25, 2023 at 12:10 pmAshish KhemkaForum Moderator
Please see if the following link helps you: Whitepaper_nCode_frequency_domain_fatigue-Halfpenny.pdf
Ashish Khemka
October 25, 2023 at 6:35 pmlouiee1907Subscriber
Thank you, and I want to ask one more question. When I do random psd vibration analysis in ncode, there is NumberOfBins in the settings. When I increase it from 256 to 1024, the life decreases. What is the ideal NumberOfBins?
- The topic ‘Damage and Cycle Histogram’ is closed to new replies.
Ansys Innovation Space
- How to apply Compression-only Support?
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Geometric stiffness matrix for solid elements
- Script Error Code:800a000d
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
624
599
591
366
