September 26, 2023 at 1:27 pm
chonkiat.lee
SubscriberI am running a harmonic analysis with modal superposition. I can see it is solved with the green tick but frequency response output with the following error... may I know what error is it?
DPF error - runtime error: self_call; mechanical::probe:173<-mechanical::time_scoping_chunk:171<-loop_over_workflow:205<-mechanical::apply_post:169<-mechanical::time_selector_incremental:170<-unit_convert_fc:167<-mechanical::change_cs:164<-mechanical::check_body_scoping:86<-requested result not found
September 26, 2023 at 1:39 pm
erik.kostson
Ansys EmployeeHi
Can you please expalin more what you are doing - show an image if possible and describe (e.g., if you have any python code or python results, etc.).
Thank you
Erik
September 26, 2023 at 1:43 pm
September 27, 2023 at 2:39 pm
chonkiat.lee
SubscriberToday I have a chance to discuss with one of the ANSYS representative but we still not able to resolve the problem.It is not about the RAM or Hard Disk.
Not quite sure about the DPF error... :( -
September 27, 2023 at 3:45 pm
erik.kostson
Ansys EmployeeHi
Please upgrade to 2023 R2 release.
All the best
Erik
- The topic ‘DPF Error – Solved but No Output’ is closed to new replies.
