September 18, 2023 at 2:35 pm
akshay akshaykulkarniak12
SubscriberHello, I am currently engaged in simulating a Full- section of a mechanical system involving a press-fit pin and a PCB using the ANSYS Static Structural Solver. After getting some warnings, i am getting error "The solver engine was unable to converge on a solution for the nonlinear problem". can you please help me with this?Â
The link for archive folder is https://drive.google.com/drive/folders/1_0kt8mwfO2vt0Zlcg7CoNzGdxGiJQIFn?usp=drive_link
September 20, 2023 at 1:49 pm
dlooman
Ansys EmployeeIf you are attempting to analyze the actual insertion of the pin, that is always difficult due to the stick slip behavior of the contact. It's much easier to model the pin geometry already in position and resolve the interference with contact. Â
September 21, 2023 at 11:31 am
September 21, 2023 at 4:10 pm
dlooman
Ansys EmployeeOh, OK. I was just hoping you didn't need to analyze the insertion process. Generic recommendations to resolve convergence problems with frictional contact are to reduce the contact stiffness, use the unsymmetric solver and insert the pin with a displacement, not a force.
- The topic ‘The solver engine was unable to converge on a solution for the nonlinear problem’ is closed to new replies.
5799
1305
