Ansys Products
Ansys Products
License not working for 2020R1
    • emeryth
      We are running Ansys 2023R1 for some professors, and 2020R1 for others. On the exact same machine, using the same ports, the 2020R1 produces the error below, however the newer version works fine.
      Is this just a limitation, or is there a work around, or is this not expected behavior?
    • Rajeshwari Jadhav
      Hi Emery,
      Are you able to ping or telnet your server, in the command prompt try using cmd “ping servername” and “telnet servername 1055” .
      To ON telnet service go to start -->search “Turn Windows feature on or off” -->check box “Telnet Client” and click ok.
      Please let me know if you are able to ping and telnet. Send the screenshot.
      If you are not able to telnet, then check PORTS and Firewall exceptions. Make sure Ansys default ports(1055,2325) are open in the firewall.
    • emeryth
      I can definitely ping. I am not turning on telnet. Like I said in the origional post though, I don't think it's a network issue, as the 2023R1 software from the same computer works fine.
    • Rajeshwari Jadhav
      Hi Emery,
      On the License Server Machine
      1. Can you go to “C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files” and open ansyslmd.lic in notepad.
      2. In the license file, just add PORT=1056 and save it
      3. Goto Start > Ansys, Inc. License Manager > Ansys License Management Center
      4. Click on View Status/Start/Stop License Manager and Restart the License Manager.
      5. Ask the user to run the application again.
      Also, remember to add 1056 port in outbound/inbound rules on clients as well as the server end.
    • emeryth
      Thank you for the reply, That line is already there. Also, our license server is on linux and we don't use the Ansys license Management Center. It's ok though I will just tell my staff that they need to update to 2023.
    • Rajeshwari Jadhav
      Hi Emery,
      Yes, please do so.
      Also, it's recommended that the Ansys License Manager should always be higher or equivalent to the latest Ansys application installed.
Viewing 5 reply threads
  • The topic ‘License not working for 2020R1’ is closed to new replies.
