August 7, 2023 at 8:57 am
AMR KHEDR
SubscriberGood morningÂ
I have ANSYS 2021R2, and I use my university license. It was working normally from a long time. Two days ago, I tried to open workbench, it started to launch givving me the launching window as shown below, and then within a second it closes without any error. Firstly, I tested the license through Licensing Client Settings, and it works. I tried a lot of solutions but nothing work.
can you please help me for that? -
August 8, 2023 at 9:56 am
Rajeshwari Jadhav
Forum ModeratorHi AMR,
Can you please check if any antivirus software is blocking the Ansys application?Â
- Go to START > Event Viewer > Expand the Windows Logs and choose Application. In application log check if any Error is shown when you launch the workbench.
Can you check while installation any error had occured?
- Goto the install.err, install_licconfig.err, install.log, install_licconfig.log logs. (C:\Program Files\ANSYS Inc)
Can you goto start menu and type %appdata%, rename the Ansys folder over there as Ansys.old and relaunch the application.
August 8, 2023 at 10:00 pm
AMR KHEDR
SubscriberYes, now it works thank you so much for your help
- The topic ‘Workbench loads without opening’ is closed to new replies.
