Electronics
Electronics
Failure at a Cosimulation between Simplorer and Maxwell
    • Sebastian
      I want to do a Transient Co-Simulation between Simplorer and Maxwell. I coupled the Systems threw loading the Maxwell Project as a Sub-System and connected the ports to the sources. Now I get the following notification: (please also see the attached picture)
      Cannot open file extnlckt.par
      What could be the problem here?
      Thank you very much for your help in advance
      Sebastian
    • Sebastian
      Due to the fact that my Maxwell System has many In and Outputs I used page connectors to connect the wires.
  • The topic ‘Failure at a Cosimulation between Simplorer and Maxwell’ is closed to new replies.
