July 1, 2018 at 6:44 pm
anupjsebastian
SubscriberHi,Â
I have been trying to import a roll cage into ANSYS Student for BAJA SAE. It keeps saying that I have exceeded the limitations. It has only 49 bodies. It does not allow me to continue my analysis. Could someone please help me with this. Thanks.
July 2, 2018 at 1:10 am
peteroznewman
SubscriberThere is also a limit of 300 faces as well as 50 bodies. If you create a zip file of your geometry and attach that to your post, I can take a look at it on a full license that has no limits.
July 2, 2018 at 1:20 am
July 2, 2018 at 1:25 am
anupjsebastian
SubscriberI saw someone else had a similar issue as me on the forum, where they had around 70 bodies. The solution was to right click and create a new part in design modeler so it is treated as a single part. The same thing doesn't seem to work for me. It still does not allow me to export or save. Â
I also tried to use a boolean and merge all the parts into a single body. That doesn't seem to work as well.
Is it possible to analyse a roll cage with so many bodies using ANSYS student? because it seems like these limits are quite easy to exceed.
July 3, 2018 at 3:26 am
peteroznewman
SubscriberI downloaded the IGES file and opened it in SpaceClaim (full license, not Student).
It shows 375 surfaces.
Note that the roll cage has surfaces for both the outside and the inside of the tube walls.
This is not the best geometry for meshing. What you want instead is a single surface at the midsurface of the tube. You need to create these midsufaces in your CAD system and export that. It will result in about 1/3 the number of surfaces, since there is also two end surfaces for each tube segment.
Read this discussion for more information and an example.
July 3, 2018 at 4:49 am
anupjsebastian
SubscriberThanks
July 23, 2018 at 11:04 am
vganore
Ansys EmployeeAnup, ANSYS provides free research version with no node/element limit for student competition teams including BAJA SAE. Your team could migrate from student version to academic research version.Â
See here more details:
/forum/forums/topic/ansys-software-based-sponsorship-for-student-competition-teams/
August 18, 2018 at 10:44 am
Ananth Narayan
SubscriberTry to open model in stp file. This opens solid as such -
August 17, 2022 at 1:07 pm
Peter Letsoalo
SubscriberHi, I've been trying to make a cooling heat transfer simulation on Fluent student 2022 R2 version, but I am not finding the intermittency transition option under the viscous model tab.
I would appreciate assistance from anyone. Thanks
- The topic ‘Limitations of ANSYS Student’ is closed to new replies.
- Stopping simulation automatically at composite failure based on displacement
- QuartodiLitro Motostudent | Fork feet analysis and optimization
- E-Racing Bergamo | Chassi’s torsional deformation
- Tress structural´s simulation using carbon fiber tubes
- Mission to Launch: Precision Engineering at UPC Space Program with Ansys Simulat
- CFD Simulation (Fluent) on Brazil FSAE CAR (FORMULA UFPB)
- Transmission System Development (Structural Simulation) Protto UFSC Motorsport
5814
1305
