Ansys Products
Ansys Products
Ansys Maxwell and Ansys Mechanical
    • Chethan
      I have designed a soft electromagnetic actuator using Ansys Maxwell 3D module on Ansys Electronics Desktop. I want to perform a mechanical simulation of the same setup on Ansys Mechanical. How can I transfer this entire setup (including magnetic field, current excitations, and resultant volume-force fields) to Ansys Mechanical for stress analysis?
    • VJ
      Hi, do you have the same version of Ansys EDT and Mechanical products installed?
      Close all Ansys products.
      If yes, go to START > Ansys EM Suite 202x Rx > Modify Integration with Ansys (run as administrator) > click YES.
      Now relaunch Workbench and it should display the Maxwell component in the Analysis systems. Drag and drop the component and import your .aedt project and then link it with other Mechanical components.
  • The topic ‘Ansys Maxwell and Ansys Mechanical’ is closed to new replies.
